Alternator - New / reburbished - Defender Source
Old September 15th, 2011, 07:09 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Guys,
My alternator is dead. Lots of other threads on here describe all my symptoms. No need to go into them.......
1) Rovers North has a new one for $229 + Shipping
2) I removed my current one, and dropped my old one off at a reputable shop in the area that repairs alternators. They are getting me a price. It is my original alternator - 16 years old. I have friends say that if you get something re-built and refurbished it is really as good as new.
I have not gotten a price back yet - should tomorrow.
Question:
1) If the shop says they can re-build / refurbish my existing alternator, is that an OK thing to do?
2) What we be the cost point when I should just go with a new one?
Thanks for your opinions!
FLAGG
Old September 15th, 2011, 07:33 PM
find a oem magnito merelli [sic] or have yours rebuilt. The new ones are junk in my experience.
Old September 15th, 2011, 07:45 PM
I wouldn't recommend a rebuilt Marelli. It appears that OE Marelli parts are not available to consumers, what you'll get are chinese fakes. Ask me how I know.
However, if the ONLY issue is bad bearings, then it would probably be OK to repair it.
Old September 15th, 2011, 09:30 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Even worse on the rebuilts, sometimes they just don't replace things. Just dealt with a bad regulator in a NAPA rebuilt unit that I got a year ago. Regulator had a date stamp of 1994 on it! Was able to track down a new regulator finally, just wasn't going to put in a third NAPA alternator after 2 going dead in two years (First one they swapped under warranty).
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 15th, 2011, 09:31 PM
Rebuilt may be difficult as last I checked they stopped providing the genuine kit to the rebuilders to do this. I even went as far as to give them the CATerpillar kit number that is a drop in, but I ended up giving up and buying new. I think I have all the caterpillar alternator numbers in my thread (I could be wrong though) but you could always buy new now and have your old one rebuilt to resell or as a spare as this process always takes a week or so it seems.
Old September 15th, 2011, 09:33 PM
Hans's Avatar
Hans
Hans Haase
Originally Posted by rijosho View Post
Rebuilt may be difficult as last I checked they stopped providing the kit to the rebuilders to do this. I even went as far as to give them the CATerpillar kit number that is a drop in, but I ended up giving up and buying new. I think I have all the caterpillar alternator numbers in my thread (I could be wrong though) but you could always buy new now and have your old one rebuilt to resell or as a spare as this process always takes a week or so it seems.
That's ironic about the CAT part number. When I was searching for parts for mine, it seemed that the IF series alternators were always listed for Ford or Allis Chalmers tractors of all things.
-Hans
My oil line fix
Old September 15th, 2011, 09:41 PM
I got one from will tillery I think its for a chebby works fine.
I also had the stocker from my 91 Classic rebuilt and the guy was able to up it to 110 amps I believe. Cost was cheap, I have not tried it on the Defender yet.
Old September 16th, 2011, 12:45 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Second Will...... had a rebuilt Morelli, lasted 2 days. Bad luck? idk
Old September 16th, 2011, 07:43 AM
Will had nothing when I called, so I went to his source. May save you a few bucks.
Old September 16th, 2011, 08:11 AM
http://www.bputah.com/Parts/Alternat...er_Classic.htm
Old September 16th, 2011, 08:54 AM
Flagg's Avatar
Flagg
Flagg
Thanks for all the quick advice!
Flagg
Old September 16th, 2011, 09:19 AM
That looks like the same one I bought from Action Alternators, but I got mine for $199.
Bought the amp from Action Alternator and Starter, Inc. which is the company Will Tillery uses.
They had the stock 85 and 100 AMP versions as well as a 140 AMP version that people have been running in their Defenders and Discos, which I bought.
Action Alternator and Starter, Inc. - 801-292-1270
http://www.actionalternator.com/
Good luck, Flagg.
Old September 16th, 2011, 09:38 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
FWIW, it may be a better idea to start looking to adapt a very common alternator as we do with the series trucks. The oem's are just going to get more expensive and harder to find, rebuilts these days can be hit or miss. Plus it's a benefit to have an alternator that is on the shelf at any auto parts store and is available in a variety of outputs.
Old September 16th, 2011, 09:54 AM
Just for your own shopping pleasure the pictured item in the above link is your standard issue Delco CS 130. You can get these in high output up to 220 amps. Usually you see them in their standard 130 A form. I found one at ASP Wholesale in 220A form for $198.20. I have used them before to get parts. I'd buy from them. The 220 puts out 115A at idle. Wow. Welding anyone?
They are a Freightliner OE alternator.
------ Follow up post added September 16th, 2011 10:31 AM ------
If you can find a blown CS 130 that is rebuildable, the same source has a 220 amp rebuild kit for about 105 clams/
Old September 20th, 2011, 07:35 PM
Flagg's Avatar
Flagg
Flagg
"find a oem magnito merelli [sic] or have yours rebuilt. The new ones are junk in my experience."
Just FYI.
I ordered a pro-line unit from Rover's north. A day later I got an E-mail that they were out of stock - and felt really bad about it - but they had a re-built oem magnito merelli alternator on the shelf that they would send for the same price with the same warranty ($229 / 1 year). They said you will not be able to tell that this one is not new. They said new this is like an $700-$800 part.
I took it. So now I am getting a re-built original. I think that is a better deal..........
Bottom line - I am hoping to have my truck back on the road next week
FLAGG
Old September 20th, 2011, 07:42 PM
61rover's Avatar
61rover
John Crouse
I took mine to a reputable shop in Denver and it was less than $50 to have it completely rebuilt and it's been bulletproof.
Old September 20th, 2011, 09:41 PM
Flagg's Avatar
Flagg
Flagg
Place near me said it could not be rebuilt. Everything was in need of replacing......and the housing was cracked.
FLAGG
Old September 27th, 2011, 11:03 PM
Flagg's Avatar
Flagg
Flagg
Update:
New Alternator installed. Engine starting, and sounding better than ever. I think my alternator had been chirping and making noises for well over a year now.......I forgot how quiet and smooth the engine could sound.
FLAGG
Old January 16th, 2013, 12:56 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Dredging this thread up...., Im wondering if Im out of luck on a higher amp alternator for us 4.0 guys. Action Alternator only has a rebuilt MM 120 amp for nearly $300 shipped. Anyone have a source?
Old January 16th, 2013, 01:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Got a rebuilt Bosch under $200 for a 4.6 on eBay. Works fine.
- Charles Eames
alternator
