Alternative diesel compatibility - Defender Source
Old February 12th, 2007, 04:20 PM
I now have a 2.8 in my Defender. I am also in the military, where JP8 has replaced diesel as the common source of fuel for all diesel engines. My assumption is that I can use JP8 as a substitute for diesel, but I'm afraid to assume with my brand new, non-mil spec expensive 2.8. Can anyone chime in? No guidance in the electronic manuals from international on this?
Old February 12th, 2007, 05:28 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Jet fuel is thinner than normal diesel as I understand it. I know that the military have an up graded pump for the GM diesels that has some hardened parts to deal with it. You might be ok with a newer engine but I'd use some sort of additive to add some lube to the fuel.
Old February 13th, 2007, 12:06 PM
pendy's Avatar
pendy
jim pendleton
89'd90
My understanding is its not the "lube" quaility but the aromatic instead. I'll send you a link Mark.
JP
I think the age, type of the seals in the injection pump will be okay. Everthing should be "nitride" quaility in that version of the Bosch VE pump.
legend in my own mind
Old February 13th, 2007, 01:15 PM
So when my maintenance sergeant offers me a 6 gallon can of JP8, should I say 'No" or "yes"?
Old February 13th, 2007, 01:21 PM
It depends on whether or not you want to get investigated!
Old February 13th, 2007, 01:28 PM
I'm national guard. rules are different!
Or at least the game is.
Old February 13th, 2007, 02:20 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
So can you sneak me out an M1A1?
Jimmy Buffett
Old February 13th, 2007, 04:25 PM
Possible, but unlikely. The motorpool security have no life, and watch them like hawks.
Old February 13th, 2007, 05:44 PM
flippedrover
Tyler
'94 D-90
Damn.
Jimmy Buffett
Old February 13th, 2007, 06:12 PM
Good luck getting it far anyway - you'll probably break a final drive, snap a torsion bar, or run out of JP8 before you get it home.
Old February 13th, 2007, 07:36 PM
the first 2 unlikely, but the 3rd is a certainty.
Old February 13th, 2007, 07:55 PM
flippedrover
Tyler
'94 D-90
I can try. Hitch up a tanker to it and I'm set for what a mile maybe?
Jimmy Buffett
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Defender 90 diesel engine and Electronics? x0054 Defender Technical Discussions 1 July 30th, 2005 10:43 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
