Alternate Parts List - Defender Source
Old November 5th, 2014, 01:31 PM
Does anybody have a alternate/cross reference parts list for our trucks? I'm pretty sure this has been discussed in the past but I can't find the list.
Thanks!
Old November 5th, 2014, 02:25 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
On the header click on Tech Articles and then go about half way down on the left side.
Old November 7th, 2014, 12:09 PM
djrover's Avatar
djrover
Dave Johnson
'91 RRC
Not sure who maintains that tech site...but here are some other replacement parts that i have found over the years...mostly for RRC, but applicable to other Rovers too...
Here is a list of parts that "seem" to work OK when a Genuine part is not available.
Ignition Coil - Most parts chains have a number of options in-stock, including BWD E504.
Ignition Wire Sets - again, most chains stock something like the Denso set# 671-8139
A/C Expansion Valve - tough to find item for some Range Rovers Classics (89-94), try oreillyauto.com for Murray Part#38733 to replace the hard to find AC expansion valve on some early RRC's.
Main/Fuel Pump Relay- Try autopartswarehouse.com for Bosch part# W0133-1631929 to replace the silver 0 332 014 112 relays.
Cruise Control Vacuum Pump-a few options are out there. Look on eBay for a used Saab 900 or 9000 pump, you will have to splice your old connector on, otherwise perfect replacement. Check summitracing.com for Dorman#904-214, again you will need to splice in your original pigtail.
Heater Blower Motor - Try part # W0133-1652002 from partsgeek.com to replace Range Rover Classic Heater Blower Motor RTC6693.
U-joints for driveshafts on Range Rover Classic and Discovery, try Neapco Part No. 1-0005, available everywhere.
Ignition Module (Ignition Amplifier Module) - If you have your original ignition module it is likely a 2 wire connector. Newer replacements use a 3-wire connector (STC1184) and will require a cable to convert your 2-wire harness to the 3-wire amplifier. Or you could simply make your own. There are 2-wire version still out there as they are used on Austin Martins and some Fords (Fiesta?). You can find it under Transpro Part#LM122 as well as a number of others
_________________________
Dave J.
'91 RR Classic
'01 RR 4.6 HSE - Gone!
'00 Disco 2 - Gone!
'95 Disco 5-Spd - Gone!
'92 RR County SWB - Gone!
'63 2A SWB - Gone!
Old November 7th, 2014, 06:21 PM
Discoweb has a parts cross reference in the tech section IIRC.
Old November 7th, 2014, 07:16 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
http://www.discoweb.org/parts.htm
Rent my
part, parts
Alternate to new M998 LED tail lights for the trailer ezzzzzzz Smaller Projects 1 April 25th, 2014 01:23 PM
Have we sunk so low? (alternate version) ontheway Misc. Chit-Chat 1 August 29th, 2012 03:36 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
parts list for 90 and 110 mpodgorski For Sale - Parts 1 June 20th, 2004 09:17 AM
Parts list and instructions Joe P Misc. Chit-Chat 0 February 13th, 2004 12:11 AM
