Alt W for Tach and What's this Sensor? - Defender Source
Old March 22nd, 2015, 06:28 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
This is on a 2.5TD...I am hooking up a Tach and need to know which is the W Terminal that I connect the pulse wire to? In addition what typically does a 2.5TD idle at?
I am also hooking up a new water temp gauge and was wondering if this was the current sensor for that or is this the oil pressure sensor? There is no sensor at the Thermostat housing...BTW that is the left rear of the motor behind the turbo...
ID:	116679   Click image for larger version
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 22nd, 2015, 07:35 PM
Hard to see the picture but it does not look like it has a W terminal. You need to pull the back off and add one.
Download the workshop manual to get idle specs and adjustment procedures.
Old March 22nd, 2015, 07:36 PM
Yes that is the coolant temperature sensor on the back of the head.
Old March 22nd, 2015, 08:57 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That makes the swap a very easy job...not even a drop of coolant I imagine...
Old March 22nd, 2015, 09:15 PM
Appears that the tach wire goes to one of the connections under the black cover. Probably the small wire. Don't know what's going on with those blue wire taps but they are giving me a rash.
Old March 22nd, 2015, 09:20 PM
It might be #2 on the picture. Hard to see. The black connector is two power and the sense wire.
Old March 22nd, 2015, 09:22 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Looking at a few online I think it's the one I marked as TWO...will have to get in there tomorrow with a mirror...
------ Follow up post added March 22nd, 2015 09:26 PM ------
Me too...not sure was tapped off of those...I see a few around the engine comp that were tapped but no wire attached...there must have been lights or something else attached that is no longer...will prob pull them out and wrap with tape...
BTW I am putting a fuse block with 4 fuses in the engine comp just for things like headlights, driving lights, etc...is there already a main wire from the battery there or do I have to bring one from under the seat directly there...?
Old March 22nd, 2015, 09:28 PM
Yah #2. Should have a W next to it.
ac, sensor
2.5NA for sale with radiator, new alt and timing kit ontheway For Sale - Parts 5 December 3rd, 2014 11:10 AM
3.9 Distributor, Alt and AC compressor Baldewin For Sale - Parts 5 November 19th, 2013 07:42 AM
Tach to Alt connection? tomaco1 Defender Technical Discussions 9 July 11th, 2009 12:04 PM
Koenig Seats and MG Alt. for sale tmore For Sale - Parts 3 July 26th, 2006 11:53 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
