Alpine Window Template - Defender Source
Old April 19th, 2010, 09:23 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Can someone with alpine windows removed trace the opening on some posterboard or cardboard for me? I am most interested in the position in relation to the interior roof ribs and sides, plus the exact size of the opening.
Thanks!
Semper Fi!
Old April 19th, 2010, 09:24 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I will try to get the windows boxed in the next day or two, work has been busy and I forgot.
Old April 19th, 2010, 09:58 AM
I have been meaning to replace the seal on one of mine (have done the other already). If you want to come by I can pull the old seal and you can take any measurements you need.
charles
Old April 19th, 2010, 10:28 AM
Ron Brown has the roof off Tony's old truck sitting there with no alpines in it....
Old April 19th, 2010, 10:31 AM
I'm a tad closer. They should be symmetric right? I have the headliner installed, but I'd think outside measurements should be all he needs.
Old April 19th, 2010, 10:49 AM
rovertrader's Avatar
rovertrader
Dale
Just lay the glass on the roof for a template, mark around it with a sharpie, cut it removing the mark, and it fits perfectly- done many that way.
Old April 19th, 2010, 11:11 AM
Wolf Fabrication
Sterling Archer
'08 D3
Yes, I know, thank you. I am also interested the in the "correct" placement of the window, and allowing the correct amount of space for the gasket.
Semper Fi!
window
Alpine Window Seals bjf Defender Technical Discussions 14 January 3rd, 2010 06:30 PM
Alpine Window Seal RyanS Defender Technical Discussions 7 July 31st, 2007 10:19 PM
need help with 110 alpine window measurement Cirbo Defender Technical Discussions 2 January 26th, 2007 02:12 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
alpine window jperakis Defender Technical Discussions 5 January 29th, 2004 02:35 PM
