Alloy Wheel lug torque spec? - Defender Source
Old June 2nd, 2015, 11:00 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
What is the recommended torque spec for a capped alloy lug nut on an alloy wheel application?
Old June 2nd, 2015, 11:15 PM
Oh good grief I had this figured out years ago.....but can't recall if alloys are 115 and Steel 95 or is it the other way around. Someone help. My brain is failing.......
Old June 2nd, 2015, 11:41 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
It's the other way around. 95 for alloy and 115 for steel.
Black Rhino Lives Matter
Old June 2nd, 2015, 11:50 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
I had a first a couple of months ago. I was walking up to the Range Rover and noticed one of my lug nuts was missing. Well on close inspection, not missing, but the head broke off leaving the narrow section still nicely screwed onto the stud and the other part vanished into roadway heaven. Never, ever had that happen before. The point, perhaps don't over tighten them. Most likely was the boob with an impact gun at the dealer.
Old June 3rd, 2015, 05:31 AM
Thank you Comrade!
Old June 3rd, 2015, 04:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
The Rover lugs are so crude compared to my *modern* Ford Excursion which actually has decent lug nuts...
Rent my
alloy, wheel
Torque spec for balljoint bracket to Salisbury Axle?? Wilboro Defender Technical Discussions 0 May 16th, 2015 10:02 AM
Torque spec's for thermostat housing bolts Roover Defender Technical Discussions 2 May 17th, 2014 07:58 PM
Alloy Wheel Lug Nuts - Defender, D1, RRC Miller Wanted 5 September 18th, 2012 06:09 PM
Torque Spec Grover Defender Technical Discussions 6 June 7th, 2010 08:21 AM
Wheel Lug Torque 75,85,95,125 pcscharfe Defender Technical Discussions 9 June 12th, 2008 11:17 AM
