Alloy on the Bonnet - Defender Source
Old October 5th, 2011, 08:25 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Alloy on the Bonnet
Has anyone ever seen a bonnet spare tire carrier that would work with an Alloy wheel?
I just got one, but it only works with a steel wheel, and before I get the steel wheel, I was wondering if getting the alloy on the bonnet is even possible?
Old October 5th, 2011, 08:31 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
what's the actual problem? threads to short?
Old October 6th, 2011, 03:13 AM
They require a full diameter hole in the middle. Should be easy to make something up
Old October 6th, 2011, 09:24 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
yep, if you have the 3 prong set up they just need to be spread a little.
Old October 6th, 2011, 09:26 AM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
There's a 3-studded holder for alloy wheels, part no. ALR2380, callout #14 here -
Also, have a look at this - http://www.defendersource.com/faq/Body/BodyHood.html#Tire
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old October 6th, 2011, 01:23 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I was going to post the above ^^^^ earlier but got called away at work.
I've got a (well, "half") of the 3 studded holder here, it's a normal steel one, with 3 holed drilled in it to line up with 3 of the lug nuts.
Mine doesn't have the studs attached, but i assume it's just 3 studs welded in, and you then use normal alloy lug nuts to fix the wheel in place.
To mount the metal ring onto the bonnet itself, you need the 2 large washers (number 18) that go under the 2 fixing bolts (number 16)...
You place the bolts through the metal ring, the the washers go under the ring (and thus directly on top of the upright posts), this stops the ring from dropping down right onto the bonnet.
Old October 6th, 2011, 08:13 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Mine is the alloy wheel bonnet mount.
Old October 6th, 2011, 09:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
You don't happen to have any pics do you?
Old October 6th, 2011, 09:38 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
if you need something made/fab'd up let me know Tom we will work something out.
Old October 11th, 2011, 09:27 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
if my kid returns my camera safely in the next couple of days, ill take some pics
alloy
Bonnet Mount Spare Adapter for Alloy Wheels Manimal Wanted 0 March 14th, 2009 12:47 AM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Military Bonnet Latches jabber Misc. Chit-Chat 1 March 8th, 2005 12:01 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
Scratch and dent bonnet ronward Wanted 2 January 13th, 2004 11:32 PM
