Alloy lug nuts - Defender Source
Old April 10th, 2012, 09:41 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Alloy lug nuts
Alright now that I'm replacing my steel wheels with the zu alloy mach 5 ones I need the alloy lug nuts. Rovers north has them at $7.80 a piece, costing me $180 for 23 of them... way too much. Anyone know anyone else selling some, or is the best bet to buy cheaper ones across the pond and have them shipped over in a big manila folder.
thanks in advance
Old April 10th, 2012, 09:45 AM
Tons of threads on this, just search. Here's one with a few sources...
http://www.defendersource.com/forum/...light=lug+nuts
Old April 10th, 2012, 09:55 AM
USLandy's Avatar
USLandy
Andrew
defender 90
thanks for the link, I'm just slightly confused I guess about how I can still use steel lug nuts which are made for alloys...?? or do the lug nuts have to be alloy too???? essentially would these work??
http://www.roverparts.com/Parts/NRC7415A.cfm
Old April 10th, 2012, 09:59 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
nuts
I can pick some out that I have been saving for a rainy day, I just went to steel wheels so I don't need. not sure on how many good ones I have. will look tonight if that helps.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 10th, 2012, 10:01 AM
The steel ones in your link work
USLandy's Avatar
USLandy
Andrew
defender 90
If you have a set of 20 that would work well, if so let me know cost wise what you would want
------ Follow up post added April 10th, 2012 09:02 AM ------
great, thanks very much
Old April 10th, 2012, 10:07 AM
wait, do you have zu alloy rims or Mach 5 rims?? Post a photo of your rims.
If you have the Mach 5 rims, then just use a regular nut, otherwise; if you have the zu alloys, then you can use the ones in the link above, which are the stock lug nuts.
Old April 10th, 2012, 10:56 PM
roverman2010
1985 LR 90 200Tdi
Nuts
I have nine, 8 out of 10. seven 5 out of 10 some dents top and two 4/10 solid chromed but some peeling. I might have three good ones on the D1 spare but will have to check in the day light.
all have the chamfered edge. if any good I can take pics, but remember these are used.
cheers
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 11th, 2012, 07:19 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Thanks for all the response, Roverman I just ended up biting the bullet and ordering a whole set but I do appreciate you going through and finding those. When the rubber comes in and I get it all mounted I'll post some pics!
Old April 11th, 2012, 10:37 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
18 out of 20 of my OEM lug nuts have swelled and the 1 1/16th socket will not fit. Water has gotten under the caps and caused expansion im guessing..replacements are expensive as i have replaced some before....what a complete pain.... I imagine a better replacement is solid RRC lugs? Ill have to do some research. Sry to hi jack but sounds like Andrew is all set and im going through this issue as well. Thanks for any thoughts and suggestions
Old April 12th, 2012, 01:10 PM
Rufus's Avatar
Rufus
Rufus
I am looking into it and finding the RRC solid lugs are only available in Crome? or do they have them polished and i can't find them? the only polished versions i found were had caps and i am looking for solid lugs. Thanks for the help with with this - I can't get my wheels back on with out new lugs....
Old April 12th, 2012, 01:39 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
You can probably get your stock lug nuts and wheels back on and tight with a 1 1/8" socket while you look for a replacement. My caps were damaged on mine and they all came off with the 1 1/8" socket and breaker.
Old April 12th, 2012, 02:57 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
They should be galvanized not crome
Old April 13th, 2012, 07:08 AM
winn442's Avatar
winn442
Winn Bearden
LA Wheel and Tire has chrome plated ones without that tin cap that swells and keeps your socket from fitting....the chrome is thin and will either flake off or rust after a couple of years, but the price is very reasonable, you can replace them twice for what OEM lug nuts cost.
Winn Bearden
alloy
Lug Nuts for Alloy Wheels lrnasd90 Wanted 3 December 23rd, 2010 05:41 AM
Lug nuts for alloy wheels d90boy Wanted 13 March 22nd, 2010 02:39 PM
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
lug nuts NashvilleRedD90 Wanted 4 November 3rd, 2005 03:37 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
