Allisport Radiator Coolant? - Defender Source
Old September 7th, 2016, 01:37 PM
Got one going in this weekend. Is standard coolant acceptable? Is there a better option?
Old September 7th, 2016, 01:57 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Just good green coolant and distilled water and you want to be fancy no brass fill cap and earth it to the chassis.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 7th, 2016, 02:22 PM
So will the typical brass filler caps essentially react with the aluminum and result in galvanic corrosion?
Old September 7th, 2016, 02:29 PM
roverman2010
1985 LR 90 200Tdi
I did ask this Q with Alisport no anwser to that but did say something about making ally ones. There are other alley rad builders that say not to use brass in the long haul.
I am sure every body has an option, but it's your call in the end. I use the plastic fill plug and the rad is earthed.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old September 7th, 2016, 03:50 PM
From Allisport:
HI Dave,
Just use Standard coolant and yes you can use a brass plug but use a little light grease.
Regards,
James
I still might go with plastic.
Old September 7th, 2016, 03:54 PM
I wonder why he did not make them to take standard radiator caps. It would have made more sense.
edit: Oh, you are talking about the radiator.
Old September 7th, 2016, 04:01 PM
Britpart make aluminum plugs. Britpart
http://www.paddockspares.com/catalog...ult/?q=ERR4686
Old September 7th, 2016, 04:16 PM
Thanks John. I'll order a blue bling aluminum plug. I'm a bit concerned about the brass/aluminum reacting.
coolant, radiator
Allisport td5/TDCI header/coolant tank budzny For Sale - Parts 0 December 10th, 2015 08:03 AM
Lower Radiator Coolant Hose Cold... Normal? sandman913 Defender Technical Discussions 1 October 18th, 2015 06:44 PM
Radiator Coolant Tkleis Defender Technical Discussions 13 July 4th, 2012 08:02 AM
Allisport Radiator V8 Defender90_218 Defender Technical Discussions 3 December 16th, 2010 05:12 PM
Allisport Intercooler Santiago Defender Technical Discussions 5 June 10th, 2008 10:16 AM
