Allisport oil breather Tank experience? - Defender Source
Old July 31st, 2016, 07:33 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Did some searching and didn't find much to answer my question.
Is anyone running one of these on their Defender 200TDi. What are your impressions of this product. Is it really better than an OEM or Genuine replacement part? Allisport advertises that the baffle is superior to the gauze type. Thanks for the info!
Defender 200 or 300 Tdi Oil Breather Tank - AlliSport
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old July 31st, 2016, 08:21 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I am running one on my 200tdi. I really can't compare to OEM as I swapped mine before the instal. I have no complaints.
Old August 1st, 2016, 01:01 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I'm running one on my 300 tdi , the oil plastic one was leaking so I replaced it with a new bright metal one. No complaints so far.
Old April 4th, 2017, 11:26 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Any other reviews on this thing? Noticed some oil on my filter by the recirc fitting. Assuming my standard one isn't cutting it. Don't really want to spend the money on it but with my increased fueling and boost, kinda feeling like I don't have a choice.
Old April 4th, 2017, 12:09 PM
Generally the factory one leaks because of the o-ring, simple "fix" is to upgrade the o-ring. I've used the O-ring #407087 from Napa, which is essentially a thicker-style o-ring for A/C setups. It's a cheaper fix @ $0.63, and solves the biggest complaint with the cyclone breathers:
https://www.napaonline.com/en/p/TEM407087
Old April 4th, 2017, 12:11 PM
AdamSanta85
91' D90 200TDI
See mine isn't leaking (unless an air leak is making it not perform it's job correctly). Oil isn't dripping where it inserts into the head. Oil is making its way through the recirc hose to my air filter. Not a lot but some.
I dunno I just ordered it along with the PiperX air filter. I'll report back.
Old April 4th, 2017, 12:42 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I put one on 200Tdi when I did the swap. I also did the radiator, electric fan, expansion tank and intercooler as well as hoses. No complaints.
Old April 4th, 2017, 12:50 PM
AdamSanta85
91' D90 200TDI
You're a boss. Their parts look really really nice online, just freaking spendy. One of these days ill do an aluminum radiator and electric fans.
Old April 4th, 2017, 01:00 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Adam, you could probably sell a security option on this truck dood.
Old April 4th, 2017, 01:11 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Its SHINY - so of course I had to buy one. It matches the coolant tank too.
Old April 4th, 2017, 01:28 PM
AdamSanta85
91' D90 200TDI
You want in? Still have a few grand in parts to go ($3032.40 as per my spreadsheet)... under body protection, lots of SDO bits, upgraded turbo yadda yadda... and that is if I don't go for air conditioning or a soft top.
Old April 4th, 2017, 06:55 PM
1of40's Avatar
1of40
1of40
I'd need to find a way to part with one of mine. 😜
Old April 4th, 2017, 09:44 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
The plastic one need (as mention before) new o'ring once in a while. You can also clean it. If, along the years, gunk come blocking it, you will get pressure and, the paper air filter will get oily. If both action are properly done and you still get an oily paper air filter... Might be something else (blow by pressure?)
My opinion regarding this is, the cheap plastic one should do easily the job.. the bright shiny metal one is.. the bright shiny one...
My 2 cdn cent.
Old April 5th, 2017, 09:51 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
This is a good topic for us that are still running gas engines. I've been kickin' this idea around for awhile. I've thought of taking the mesh breather out of my pass side valve cover, cutting it down short, removing that dirty 'ol mesh, welding the top back on and running to a catch can then run hose to the intake. This I hope would reduce the normal amount of oil and water vapor going into my intake and gumming up the works. Sorry to take over any/or butt in on the thread. Just thought while the topic came up I would try for a little feedback.
Old April 6th, 2017, 08:13 AM
1of40's Avatar
1of40
1of40
Generally the factory one leaks because of the o-ring, simple "fix" is to upgrade the o-ring. I've used the O-ring #407087 from Napa, which is essentially a thicker-style o-ring for A/C setups. It's a cheaper fix @ $0.63, and solves the biggest complaint with the cyclone breathers: https://www.napaonline.com/en/p/TEM407087
Thanks Lav, I need to try this^^. My breather tube is currently directed to a dry spot inside the engine bay and I'm getting barely any seepage. I mean barely anything. I've been wondering if this could be because my unit is not properly sealed. Skinny Pete and I tried testing it once and it didn't seem to hold pressure.
breather banjos and/or breather kits cgalpin Defender Technical Discussions 2 May 28th, 2016 11:29 AM
Allisport td5/TDCI header/coolant tank budzny For Sale - Parts 0 December 10th, 2015 09:03 AM
Allisport TDI breather Overlander Wanted 5 December 31st, 2014 01:35 PM
Allisport Header Tank Landy_Andy For Sale - Parts 7 December 16th, 2013 12:08 AM
AlliSport 200/300Tdi/V8 Aluminium Header/Overflow Tank timtimtj For Sale - Parts 3 January 17th, 2011 09:19 AM
