Allisport model question. - Defender Source
Old July 20th, 2012, 06:11 AM
maleger
Marc-Andre Leger
I'm getting ready to put in an Allisport radiator and will also change the oil coolant lines at the same time. Does anyone here have this setup ?
I would like some help, I have an early NAS 94 D90 with LT77 ( I think S). I have A/C but am removing it, as I never use it. On the Allisport ebay store they talk of a model with oil cooler lines for the 1995 NAS Defender, is the same model required for the 1994 D90 with the manual tranny ?
I will get the one with the shroud and fans. I'm replacing the Kenlowe fan and the stupid relay switch that keeps failing every time it rains (or so it seems). I also need to get the X-Eng Aluminium in-hose adaptors and install a standard thermostatic fan controller. I was rather disappointed with Kenlowe, I would be at my 3rd relay control module and 6th relay in about 2 years. Considering the price, I was expecting more reliable products.
Old July 20th, 2012, 06:23 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
That is about as reliable as you will get with electric fans. Not trying to be negative but you'll do well to save the standard engine driven fan if you want reliability.
Matt Browne
Old July 20th, 2012, 06:29 AM
maleger
Marc-Andre Leger
It was overheating in traffic with the standard VC fan. I also wanted something I could stop for wading.
Old July 20th, 2012, 07:21 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you carefully remove the A/C you should be able to sell it here where it is hotter. Always a market for them used here in the States
Land Rover 110
Old July 20th, 2012, 07:45 AM
maleger
Marc-Andre Leger
A/C
I did read the thread on A/C removal. I'm going to find a shop to empty it first and then take it out. Not sure what part of the dash console to remove, but I'm sure I'll figure it out.
I'm going to hang on to it until I'm really sure I don't want it any more.
Old July 20th, 2012, 10:55 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
If everything is working properly it should not overheat especially in Canada
Old July 20th, 2012, 01:26 PM
Yep ... should not overheat ... head gasket time!
Old July 20th, 2012, 01:27 PM
maleger
Marc-Andre Leger
it gets pretty hot here in Montreal in the summer. Forecasts are in the mid 80's this week. But stuck in traffic on black pavement, it's a lot warmer. At low revs, bumper to bumper, moving a few inches at a time it does overheat.
The only thing not changed is the coolant pump, but I have one on standby in my basement. I decided to put it on a new engine I will get installed in the fall, likely a 4.2 pulled from a RR and rebuilt.
Old July 20th, 2012, 03:50 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
80's ? It's over a hundred here and it hasn't rained since February. If you don't need your AC it's not hot there...period...and definitely not hot enough to overheat your truck.
I have no electric fans... Just the original factory standard fan, Horrendous traffic....all the while running the A/C.
Not to mention on my frequent drive to Jerusalem from Tel aviv, a 2500 ft gain / 25k in elevation.
Thankfully I have no problems.
Im sorry to say.....Check your truck.
Old July 20th, 2012, 06:51 PM
maleger
Marc-Andre Leger
Yes, I will check all the cooling related systems. I suspect the electronic control of the fan is the real culprit. Thank you
Old July 20th, 2012, 07:05 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Marc, on your old white '94 it was the fan clutch that was going.
Old July 20th, 2012, 10:58 PM
Drove the 90 in the 105*+ heat wave in DC few weeks back...didn't budge an inch. If the stat and system are doing their job you shouldn't overheat at all. Something else is going on.
Old July 21st, 2012, 06:31 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
While I can understand the thought behind the wading bit, (although that thought is somewhat dated back to really bad electrics and if you are in that deep I'd suggest other issues that might warrant attention before the ignition gets wet.).
I'd check the rest of the system out. The standard cooling capacity is well within requirements and should not overheat with the standard fan period unless there is something else wrong. Not saying that you shouldn't use the electric fans if thats what blows your skirt up but in doing so you are masking an issue not curing it. (sorry, suggested skirt as it is much easier to lift up when wading )
Matt Browne
Old July 21st, 2012, 11:27 AM
maleger
Marc-Andre Leger
my old D90
How do you know that ?
Where you the person who bought it from me ?
What happend to it, I loved that truck !
------ Follow up post added July 21st, 2012 11:29 AM ------
I'm still looking to get the Allisport, I think it would be a nice addition to my urrent truck. Do I need the model with one or two oil cooling lines ? Not sure...
I have an older/early NAS D90 (1994) with the LT77S and 3.9L V8.
Old July 21st, 2012, 11:38 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I was the other guy with Brian (who bought it) who met you in Burlington. He still has it and lives in southern new Hampshire. It's a great truck.
Old July 21st, 2012, 11:45 AM
maleger
Marc-Andre Leger
It's a great truck.
Thank you, yes it was a great truck for me as well. I really regretted ever selling it.
Old July 22nd, 2012, 03:43 PM
maleger
Marc-Andre Leger
Put the VC fan back in this morning, no more overheating driving around town. So it's the Kenlowe control module that is fried, again... this would be my third. I will put in a X-Fan module and a regular thermostatic switch, nut I,ll keep my VC fan close by on long distance travels (like Argentina or perhaps a trip in central America with the group from the No-Limits X, which seems really cool).
mod
Question about value and model years. MGPete Defender Technical Discussions 1 October 30th, 2011 06:52 PM
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
