Allisport Intercooler 300Tdi w/ A/C Question - Page 2 - Defender Source
Old August 13th, 2016, 05:07 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
1991 D90, 2006 LR3
Originally Posted by Red90 View Post
On my 200TDI, with carefully set and measured fueling, no difference whatsoever. In other words, peak EGTs were the same before and after with the same fueling settings. I suspect you need to have the boost a fair bit over stock to get any gains. The stock intercooler does everything that can be done at stock boost levels.
Intercooler wouldn't necessarily affect egts...
Old August 13th, 2016, 05:41 PM
If a larger one is needed, IAT will drop and EGT will drop when running at peak boost and full throttle. If the peak (sustained full throttle) EGTs do not drop, then the larger intercooler was not needed. The whole point of putting in a larger intercooler is to reduce peak IAT and thus allow more fueling without increasing peak EGTs.
Old August 14th, 2016, 10:36 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I have the double core and ac, ran home at 70mph 105F for 120 miles today. Engine temps 180-190 (82C thermostat). I'll snap some pics tomorrow.
Old August 15th, 2016, 01:49 AM
Thanks Chris.
Old August 15th, 2016, 07:38 PM
El Solis's Avatar
El Solis
Chris Solis
Ok here you go. This was not a direct swap. You have to cut out the rad/IC tray to allow this thing to fit. I was lazy which means it took longer and I didn't drain the coolant and remove the rad hoses. I had to notch it while it was in the truck.
Top down view showing how much it sticks out.
Here is where I trimmed the fan shroud to allow for the wider IC. Still flush against the radiator. I figured that at freeway speeds and when under heavy boost i'd have enough RAM effect to be OK and when going slow off road I wouldn't need the turbo as much.
Here's how the IC and the AC condenser (I think that's what's up front) meet up. They are flush.
Hope it helps!!
Side bar: for the experts, better to have the fan shroud behind the IC or should I completely trim it away and seal up the gap for the radiator? I've read somewhere that the fan shroud is restrictive for air flow through the IC.
300tdi, ac, tdi
AlliSport 300 Tdi Double-Core Intercooler NEW KC_Michael For Sale - Parts 5 November 7th, 2014 11:28 PM
allisport 300 tdi intercooler rock90 For Sale - Parts 8 September 16th, 2014 09:39 AM
200tdi allisport full width intercooler TDI Guy For Sale - Parts 10 August 15th, 2014 03:16 PM
Allisport Intercooler Fitment Jackie Treehorn Smaller Projects 2 June 25th, 2014 01:20 PM
Allisport Intercooler Santiago Defender Technical Discussions 5 June 10th, 2008 10:16 AM
» Defender Registry
Green Mile
Jdc0430
D
drsmiley
Add your Defender
