Allisport Intercooler - Defender Source
Old June 8th, 2008, 03:44 PM
Santiago
Santiago Gigola
Hi guys,
I am thinking about buying a new intercooler for my 2.8 TGV engine. The one it has is a standard 300Tdi intercooler, quite old, doens't look good from the outside: flatttened/deformed aluminum. It was a used intercooler when installed on the 2.8 engine.
Since I will be travelling to England soon I was considering eventually buying an Alisport uprated intercooler but the standard width one, not the full width one since I will be installing AC in my Defender later this year and I do nto want have space problems when fitting the AC condenser in the front of the truck.
I am not planning to tweak the 2.8 engine right now but I am tempted to slightly tweak the fuel pump and turbo boost in the future.
a) Do you think the Allisport standard width intercooler will do better than the standard 300Tdi intercooler or is the performance going to be just the same?
b) if I install a standard width Alisport intercooler, will I only notice a difference in case I tweak the fuel pump and turbo boost or willjust changing the intercooler make a difference?
c) if I decide to go the slight tweaking route, how difficult and expensive is it to install a EGT measuring gauge?
I believe Pendy mentioned it is OK to tweak a 2.8 engine as long as you measure the EGT and keep it beneath some number which i cannot remeber. What is a decent bhp figure I can expect to achieve from my all standard 2.8 engine by tweaking it and not risking blowing it up?
Opinions are appreciated.
Regards,
SG
Old June 8th, 2008, 11:49 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The stage one from Allisport is a good comprimise and still fits without any real extra work. But it is still a comprimise.
Gauge would be a good backup.
legend in my own mind
Old June 9th, 2008, 01:38 PM
Santiago
Santiago Gigola
Pendy,
Thanks for your comment.
Is it expensive to purchase an EGT (everything, probe, gauge, etc)?
What about installation, is it complicated? I imagine the sensor is installed in te exhaust? Is this correct?
Sorry if asking silly questions, I am just guessing.
Santiago
Old June 10th, 2008, 10:36 AM
sommer_90's Avatar
sommer_90
Jeff Sommer
1994 Defender 90
EGT guage and probe are very affordable, egauges.com
http://www.egauges.com/vdo_mult.asp?...&Series=Vision
A nice easy probe location is into the EGR plate on the exhaust manifold. Just pull the two bolts drill hole and weld the bung onto it.
Old June 10th, 2008, 10:59 AM
I need to install an EGT too before I start tweaking. I thought it needed to be installed before the turbo inlet to get a good reading? I'm looking forward to hearing people spell out this installation.
Pendy,
I'm kicking myself hard for not lettting you install the EGT when you asked me about it and had the engine out. I was new to diesels and didn't know better. uhhh. send any of your conversion customers my way if they pass on the EGT and aren't experienced in diesels. I'll set them straight.
Old June 10th, 2008, 11:16 AM
pendy's Avatar
pendy
jim pendleton
89'd90
The 2.8l is a little more difficult to deal with onthe probe.
JP
Intercooler comparisons pendy Misc. Chit-Chat 8 November 6th, 2008 04:02 PM
Correct intercooler for International 2.8 engine Santiago Defender Technical Discussions 5 June 13th, 2008 04:12 PM
Intercooler D90user Wanted 3 November 26th, 2006 02:59 AM
Intercooler cleaning D90user Defender Technical Discussions 8 September 29th, 2006 09:35 PM
Tdi intercooler tube diameter artm Defender Technical Discussions 1 December 30th, 2005 12:13 PM
