October 7th, 2016, 12:47 PM
Allisport Header Tank Install Issue
Radiator and intercooler went in with only minor adjustments. The header tank on the other hand isn't going in as advertised. The bonnet prop arm gets in the way. Anybody else come up with an acceptable solution?
October 7th, 2016, 12:50 PM
91' D90 200TDI
Convert to newer style regular prop arm?
October 7th, 2016, 12:54 PM
Did that work for you? Do you have a picture or a part number?
October 7th, 2016, 12:59 PM
91' D90 200TDI
I don't have that tank. My truck has the newer style arm already. I can't see why it wouldn't work as it runs perpendicular to your current style.
I think this is the part. You just need to see if there is a spot on the bonnet it can slot into to hold it.
http://www.roversnorth.com/ProductDe...x?code=ALR9022
Check this out. I just tried to check out current pricing. Holy smokes have things gotten expensive. Maybe you can fab a couple of those items yourself instead of paying all the $$ they want now.
http://www.reedx.net/landrover/mods/bonnetstay/
This is another potential option
http://www.extreme4x4.co.uk/acatalog...TRUT_KITS.html
October 7th, 2016, 01:02 PM
Got a picture you could share?
October 7th, 2016, 01:10 PM
91' D90 200TDI
Check the ReedX link. I can take some pics of when I get home this evening if you need. This should def work for you, as it goes nowhere near the header tank.
Edit - And if the parts are too expensive now, I would buy stuff that is similar from another make and model and make it work. It is just a normal car XYZ style hood prop.
October 7th, 2016, 01:22 PM
Chris B
72 + D1 drivetrain =?
October 7th, 2016, 01:47 PM
Andy
Megasquirt UK also sell a couple of version of their gas strut kits, half way down this page :
Megasquirt for V8 engines - Off-road products
October 7th, 2016, 01:52 PM
Mike Barnett
110
Dave, there's also another kind of straight prop rod that I had on my truck. It basically sits parallel to the rib on the bonnet so should be out of the way of the tank. I would take a picture but...
October 7th, 2016, 07:11 PM
Ordered what I had on my ExMOD truck and what I believe you had.
October 13th, 2016, 03:27 PM
Problem solved.
October 13th, 2016, 03:58 PM
joshua
82 Land Rover 110 Ex MOD
Problem solved.
Sexy!
October 13th, 2016, 05:15 PM
Deaf Ember
Smart 4x4
I used a similar rod I got from Pic-n-Pull, I think from a Subaru. Mine hooks in a rectangular slot in the top of the radiator casement, LH side. Used the same hood mounting point as the stock LR unit. I love having the hood way up above my head when open. Mine does rattle at idle against the heater box though.
» Recent Discussions |
