All indicators flash...removed dash light - Defender Source
Old August 1st, 2015, 06:19 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I installed LED lights today including the correct flash relay...all four flashed regardless of the stalk position....I removed the dash indicator and it corrected the issue as it's allowing a small amount of current to pass through the bulb to the other side...how does one correct this so I can still have a dash indicator?
I searched and found the bulb removal but no one said how to rectify the issue...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old August 1st, 2015, 06:35 PM
Lemonhead
TB
1997 D90 SW
Have to put a resistor inline of the LED's - I put one on each front one and solved the same problem.
Assuming that is that you installed front and rear LED's - I didn't have any problem when I just did the rears (with correct flasher).
https://www.google.com/search?q=RL-6...l+650+resistor
Old August 1st, 2015, 06:38 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Even with the new relay...did the indicator on the dash work correctly too?
Old August 1st, 2015, 07:18 PM
Lemonhead
TB
1997 D90 SW
I initially installed rears only and changed out the flasher - all was good (dash bulb flashed as well).
When I installed the fronts is when all four blinkers flashed.
Seems not everybody has the same problem - mine's a 97 NAS. At the core of the issue I believe is the LED's don't draw enough current compared to incandescent - it may be compounded as well by the single bulb indicator in the dash.
Old August 1st, 2015, 11:37 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Will Try that! Thanks...
Old August 1st, 2015, 11:47 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Did you change out the side repeaters also? Are they burned out?
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 2nd, 2015, 06:27 AM
BlackField's Avatar
BlackField
Oscar
D110
http://www.defendersource.com/forum/...tml#post608720
Old August 2nd, 2015, 08:24 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Yes the side repeaters need a swap out but since I am going to LRD I will still need the fix...that post is perfect Oscar! Thanks.....I wish the search function was a tad better...always have to search through google!
dash, ht
Daylight Savings! Flash Sale! 25% Off! proulx70 The Vendors Loft 12 November 4th, 2014 12:48 PM
D90 Flash Drive...So Cool silby32 Misc. Chit-Chat 13 October 4th, 2012 09:36 PM
Save the dog - Flash light recommendation needed paulb Misc. Chit-Chat 21 February 11th, 2012 02:38 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
Odometer flash Weaver Defender Technical Discussions 3 December 11th, 2006 07:47 PM
