alignment question - Defender Source
Old November 8th, 2012, 12:28 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
alignment question
Anyone have experience with Firestone for alignments? I need to get the wifes lr3 aligned and Firestone is $80 vs $200 at the dealer and just tires. Firestone confirmed the price is good for a 4 wheel alignment. Should I ne concerned they are that much cheeper?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 8th, 2012, 12:30 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Would you really trust a tire monkey with your LR?
1970 SIIA 88, Sold
Old November 8th, 2012, 12:32 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
If they use lasers I would give them a shot. Some of these places even warranty the alignment. My wife's Volvo has some sort of warranty through Midas.
Although they might not have hot chicks and espresso machines there.
Old November 8th, 2012, 12:37 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Just had firestone install new tires and alignment on my wife's DII. They did a good job. Same place I've taken my camry to. They guarantee the alignment for 12 mos or 12,000 mi, and I plan on going back to check the alignment during that period.
Old November 8th, 2012, 12:54 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I wouldn't take my wheelbarrow to the Firestone place here....ymmv.
There are invariably more problems with a vehicle when it leaves than there were when it was delivered to them.
Old November 8th, 2012, 02:00 PM
I wouldn't take an LR3 because they won't be able to put it into tight tolerance mode and because of this the alignment could be totally off since the air suspension can adjust while doing the alignment. Not to mention they will probably strip out the caster and camber adjuster cam bolts in the front. Firestone is a bad life choice.
Old November 8th, 2012, 03:13 PM
lordhelemt's Avatar
lordhelemt
Paul
Humm...didnt even think to take the air suspension into consideration. I guess I'll just take it to the dealer.
I appreciate everyones feedback/comments
Old November 8th, 2012, 03:18 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
On a separate note, I had my LR3 aligned at the local dealer earlier this year and I was able to get them down to about $120 for it
Old November 8th, 2012, 03:21 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Find a LR specialist.
1970 SIIA 88, Sold
Old November 9th, 2012, 03:54 AM
sro
Sam Odio
2008 LR2
I've had a great experience with Firestone. I got their lifetime alignment service and use it regularly for my LR2. At the least I get the vehicle aligned after any major off-roading. Personally, I'm of the belief that it doesn't matter how good the alignment is, it's likely to need to be re-aligned in 6-12 months.
Don't know about the air suspension in the LR3 though...
alignment
Easy alignment question probably... mattb Defender Technical Discussions 2 October 27th, 2012 06:09 PM
Door alignment, adjustment question jayz Defender Technical Discussions 10 July 24th, 2012 12:07 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
