Alignment? - Defender Source
Old June 29th, 2014, 11:28 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Alignment?
I put a set of 35's on yesterday with new rims (finally have beadlocks now!)... Do I need an alignment? It drives straight (though that maybe the trutracs)... I had one done about a year ago....
Old June 29th, 2014, 12:13 PM
The only thing to align on a Defender is toe. You do it with a tape measurer. You do not need to take it to anywhere to get done. All clearly explained in the workshop manual.
Old June 29th, 2014, 02:11 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Mark the tires all the way around the circumference by jacking up front axle, put chalk/marker on the ground and spin the tire around. Then measure the front and back of the tire and adjust the tie rod till the lengths are equal.
Old June 29th, 2014, 04:16 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Kay, thanks for explaining the process but do I need one?
Old June 29th, 2014, 07:23 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
What I mean is does a wheel and tire change necessitate a realignment if none of the steering components have been touched?
Old June 29th, 2014, 07:56 PM
No. Nothing requires an alignment unless you touched the tie rod.
Old June 29th, 2014, 07:57 PM
But it is always good to check and only takes a minute to do.
Old June 29th, 2014, 08:01 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Great that makes sense... My tie rods have guards and are a bitch to get to... I didn't want to stick my nose in there unless I needed to... Thanks (really,not being sarcastic) for the info... It gives me a better idea of what's involved and it doesn't sound to difficult (on another truck lol)
Front Door/Rear Quarter Panel Alignment Grover Defender Technical Discussions 12 August 7th, 2008 07:22 AM
Pitman arm alignment cgalpin Defender Technical Discussions 12 December 11th, 2007 06:33 PM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Steering alignment kellymoe Defender Technical Discussions 10 November 19th, 2004 12:23 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
