Alarm Uninstall - Defender Source
Old January 11th, 2007, 11:26 PM
texasdefender110's Avatar
texasdefender110
T.J. D...
NAS Defender 110
Alarm Uninstall
The previous owner installed an Alpine SEC-8047 in my 93 110. I've been unsuccessful locating an installation guide, thinking I could follow the procedure in reverse. I have located a wire color diagram. I have unplugged the main power connector and door lock/parking light connector from the main unit and the truck still starts. I'm taking that as a good sign. Before I start tearing out alarm wiring, any tips for an alarm removal?
--T.J.
Old January 12th, 2007, 12:22 AM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
For the most part an alarm is simply a glorified switchboard so you shouldn't run into much trouble depending upon what it's triggering.
Is there a remote start? (highly doubtful on that vehicle) If so, you'll need to be careful removing this as its connected to rev indicators and other engine components.
Is there a starter kill? This is going to be the biggest hurdle b/c most alarms are designed to trip the starter kill if the alarm is tampered with. That being said, it sounds like you're in the clear if you have already disabled the unit and the vehicle still starts.
WTB: D90 Dash Dimmer Switch PCRover Wanted 1 January 11th, 2008 09:18 PM
D90 Alarm System? icurnmedic Defender Technical Discussions 4 May 30th, 2006 12:26 AM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Bad Flasher tic-tock?! OCD90 Defender Technical Discussions 4 December 13th, 2005 02:13 AM
Clicking from the dash? greg_sikes Defender Technical Discussions 14 November 9th, 2003 07:31 PM
