AirRaid vs. K & N air filters - Defender Source
Old December 13th, 2011, 11:34 PM
cdb
Clark Bowen
I've had plenty of experience with K & N filters, but I wonder how Airraid stacks up against them when used offroad or in dusty situations?
2011 RR HSE -
2001 GMC 2500 4wd
Old December 14th, 2011, 07:28 AM
Junk. Hard to beat the filtration of stock paper filter. I thought beth airarde used a k&n
Old December 14th, 2011, 07:45 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Stacks up against a K&N? You mean you want something that lets through as much dirt as a K&N?
Not many people know, but K&N clearly states on their web site that using one of their air filters off-road voids the warranty.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 14th, 2011, 11:44 AM
cdb
Clark Bowen
Who is Beth Ararde?
Yes I know it is an ongoing debate about K & Ns and dirt and I don't use them on my diesel, but I also don't buy the argument that a paper filter is best for a higher performance gas motor in a dusty climate.
What do they run on the Dakar, European rallies, Baja 1000? Paper, foam, oiled cloth? I Googled and couldn't really tell.
I do know that I have been through plenty of "bull dust" in Nevada that is so fine it flows like a liquid 8" deep as you plow through it and never had a problem with K & Ns. Never. Never had the oiled MAF issue either.
So why are AirRaids junk? Specifics.
2011 RR HSE -
2001 GMC 2500 4wd
Old December 14th, 2011, 12:18 PM
Engine longevity is not exactly a concern for racing. They will rebuild engine regularly regardless.
Filter efficiency tests have been performed and the K&Ns do not fair well. If people want more flow, less restriction fit a larger filter.
------ Follow up post added December 14th, 2011 10:36 AM ------
http://www.aulro.com/afvb/technical-...s-finally.html
Old December 14th, 2011, 02:30 PM
The stock air box on a 90 should flow pretty good. I would imagine with a blower lack of fuel not air should be your worry. Are you running an air fuel meter?
Old December 14th, 2011, 03:59 PM
cdb
Clark Bowen
Actually, the motor is in my 1995 RRC.
I wanted to do away with the stock airbox as it seems to restrict airflow at higher load, but I'd lose the protection against water when wading. Exposed paper filters would be vulnerable to wading issues too.
I thought about enlarging the intake and exit holes of the airbox, but I don't trust glued joints to hold up to offroad pounding.
That is why I was looking at K & N and AirRaid filters with a pre-sock.
------ Follow up post added December 14th, 2011 01:01 PM ------
Yes, I have 2 AFR gauges
------ Follow up post added December 14th, 2011 01:08 PM ------
Thanks John.....
That was a very help filter study.
Funny, K & N doesn't have it on their site. They have every other hype.
I think I'll stick with the stock filter and housing for now and sees how it goes when it is on the dyno.
2011 RR HSE -
2001 GMC 2500 4wd
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Are K&N, Amsoil, etc air filters worth it? cdb Defender Technical Discussions 8 July 19th, 2007 08:38 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
