Aircon repair - Defender Source
Old August 18th, 2013, 12:06 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Aircon repair
How do I make my airconditioner colder and work better? Also has anyone used Ac Pro
Old August 18th, 2013, 12:22 PM
Based on the generality of your question I would suggest you take it to a car mechanic who specializes on A/C systems.
Old August 18th, 2013, 01:33 PM
Landyman1's Avatar
Landyman1
Landyman
Where can I find the low side air con service port on a land rover 3.5l v8?
Old August 18th, 2013, 01:42 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Mine blows too cold. You must be low on gas.
Old August 18th, 2013, 03:12 PM
Moved thread into technical discussions.
Old August 18th, 2013, 03:16 PM
Landyman1's Avatar
Landyman1
Landyman
I've got a full tank
------ Follow up post added August 18th, 2013 01:18 PM ------
I think my car needs more aircon fluid. Where would I be able to refill it on a 3.5l v8
Old August 18th, 2013, 03:29 PM
You think?
I'd find an expert and let them refill it properly. Costs around $80 and takes about 30 mins.
Old August 18th, 2013, 07:45 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Keep in mind that it's not as easy (to do the job correctly) to just dump more refrigerant (gas) into your system. Properly done the system should be evacuated and filled... If any moisture or other gases are introduced, the system won't operate optimally. Sounds like you should take it to an AC shop.
Old August 18th, 2013, 11:52 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
in that order: purge - vaccum - fill
- Charles Eames
Old August 19th, 2013, 10:03 AM
Landyman1's Avatar
Landyman1
Landyman
Thanks so much
RECO: Repair Manual for 95 SW reaper99999 Defender Technical Discussions 0 March 5th, 2006 05:07 AM
Door Panel Repair? boshea Defender Technical Discussions 3 January 17th, 2006 04:13 PM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
Speedo repair artm Defender Technical Discussions 3 October 21st, 2004 08:33 PM
roll cage repair willtillery Defender Technical Discussions 0 October 4th, 2004 09:15 PM
