Air Vent Pins - Defender Source
Old January 8th, 2012, 05:05 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Air Vent Pins
Anyone know where I can buy new Vent pins. Is there any other styles out there or am stuck with prying the ends apart to hold them in place? Do they come in stainless or painted only? Thanks for the advice.
Old January 8th, 2012, 06:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mine had acorn nuts at the end,they're from a 1999, but I don't know where you would get them.
Old January 8th, 2012, 06:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Stephen Peters had some of the new style with the nuts. They are much better than the older style.
Land Rover 110
Old January 8th, 2012, 07:02 PM
Anyone know if they're stainless? I could use a set as well.
The only thing I could find on his website were the Series style:
http://www.safarihp.com/334121.html
Others must be a call-in item not listed.
Old January 8th, 2012, 07:12 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
I have a brand new unused set if you need them
Chris "V"
Old January 8th, 2012, 07:14 PM
Obviously first dibs to Matt...if he's not interested let me know.
Old January 8th, 2012, 07:28 PM
Rosproline157
Matt Oaks
1992 Defender 90
I WANT THEM! And thanks Jason, for thought. I did find them in the UK as well. I reall like the idea of the acorn nut too..
http://www.brit-car.co.uk/search.php...x=1&submit.y=5
Old January 8th, 2012, 07:31 PM
Id check with Rovers Down South
------ Follow up post added January 8th, 2012 07:31 PM ------
4 more posts and I am at 5000
Old January 8th, 2012, 07:33 PM
Chris Velardi
Chris Velardi
1975 101FC
Mine are the standard pins with split ends new in the origianl pack
Chris "V"
Old January 8th, 2012, 07:37 PM
Damn someone has to make them in stainless with the acorn nuts. I'm on the hunt...will report back if I turn them up.
What are these "officially" called btw...just vent hinge pins?
Old January 8th, 2012, 07:41 PM
Rosproline157
Matt Oaks
1992 Defender 90
Completely stainless would be a awesome. A touch of grease the vent would open up smooth. Let me know what you find.
------ Follow up post added January 8th, 2012 07:43 PM ------
Britcar calls them "Bulkhead Vent Hinge Pin"
part number "334121"
------ Follow up post added January 8th, 2012 07:45 PM ------
Any idea what the diameter is? I'm looking through McmasterCarr
3/16 dia x 3-1/8" long plus nut
94 Davia System AC Air Vent Rufus Wanted 14 February 3rd, 2011 11:00 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Air Vent Lever Control - hi/low Flagg Defender Technical Discussions 23 November 18th, 2006 02:08 AM
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
