Air purging jacks - Defender Source
Old March 3rd, 2004, 10:36 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Air purging jacks
Another tip, back a couple weeks someone asked about "purging" air from bottle jacks. I found an old instruction book and they said that after filling up the jack (lay the jack on it's side with the fill hole up, fill to 1/4" below hole) open the pressure valve (as if you are lowering the truck) and pump the handle 15-20 times rapidly. It worked for my floor jack that had run low. If nothing more, worth a try.
Best regards,
Old March 3rd, 2004, 11:50 AM
Cool
Old May 12th, 2007, 10:24 PM
I accidentially drained all the oil out of my bottel jack, i have tried to bleed it with no luck. Bleeding the clutch on a drill rig is easier than dealing with this thing... I have no clue how to bring this thing back to life
Old May 14th, 2007, 05:45 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I have the same problem with one of mine. I accidentally unscrewed the pressure valve too much and it came off, letting air into the innards. I'll have to give this a try.
Old May 14th, 2007, 11:37 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Pull the valve out and submerge in fluid. Pull the jackupwards manually and overfill with fluid. Let it sit with the valve closed and the bleeder open and facing upwards for a period of time. Later slowly bring the jack to its rest position letting the fluid spill from the bleeder.
Worked for me a couple times. Dilute a little brake fluid in it to lossen the seals it it might help.
JP
legend in my own mind
ac
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
AIR COMPRESSOR Question: norros Misc. Chit-Chat 8 March 21st, 2005 03:28 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
