Air Locker problem - Defender Source
Old May 8th, 2005, 11:40 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Air Locker problem
I have an ongoing problem with my rear ARB belching diff oil up the airline and into the cabin. The ARB probably has 3,000 miles on it. I have replaced the axle breather line and checked to make sure there is nothing clogging the opening on the axle. In chatting with ARB they told me it was the O rings in the locker. Had Moab 4wd pull the diff out and change the o rings on the diff with the ones ARB sent me. There was no change at all with the new o-rings. Arb claims that there is no other element of the locker that would let oil seep into the air line. Despite this claim, they have sent me a complete seal kit with instructions on how to "reseat" the locker. The locker engages and disengages fine, there is no problem with it at all except for this damn oil. Anyone know what's going on or have any advice?
Old May 9th, 2005, 09:40 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Yes,
I have installed upwards of 50 of these things in Rovers. It is critical to center the air line collar when fitting it on top of the o-rings. Use a feeler gauge to get the gap uniform all around, otherwise it will leak oil back into the air line when driving. Also can be more of a problem in cold weather when the o-rings stiffen up. You may have to grind a few burrs off of the inside of the adjusting nut to allow the air collar to center exactly.
Rob
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
ARB Air locker Air compressor roverguy2 For Sale - Parts 4 May 27th, 2009 03:08 PM
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Info needed on Arb air locker. rustydefender Defender Technical Discussions 5 January 9th, 2005 03:46 PM
