Air leak in breather tube - Defender Source
Old May 6th, 2013, 02:10 AM
sro
Sam Odio
2008 LR2
So, after wading my truck I decided to run a breather extension for the rear axel.
After the job I thought I'd test it out (by blowing into the tube) and I realized there's actually an air leak at the coupling (where the OEM tube joins the rear axel).
That is, I could hear air escaping through that coupling when I blew into the breather extension.
I tried tightening the coupling to no avail. Is this normal? Seems like it could be a source of water ingress...
Old May 6th, 2013, 06:12 AM
Let's hope the banjo bolt stripped and not the axle case
Old May 6th, 2013, 06:33 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You may have a seal failure at the nipple and the vent tube. I would cut it off and re-install. Also the bolt assembly uses two copper washers to seal the unit .
Old May 6th, 2013, 01:19 PM
sro
Sam Odio
2008 LR2
The bolt isn't stripped. It's on there tight.
It looks like there's a copper washer that is supposed to be on either side of the bolt. I only have one copper washer so that might be the cause.
I'll try getting another and update.
Old May 6th, 2013, 02:28 PM
mine have been weeping around the banjo bolt hole, Ive blown the lines out. I wouldnt worry about, I dont generally spend much time in very deep mud.
Old May 6th, 2013, 02:46 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This is on my To-Do list.
http://www.discoweb.org/forums/showt...ferrerid=13769
Old July 7th, 2013, 02:58 AM
sro
Sam Odio
2008 LR2
well, the problem was the missing copper washer. With both washers it seals well.
Old July 7th, 2013, 11:00 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Originally Posted by fishEH View Post
Any body with a Dweb login care to repost those images regarding the diff breather?
It looks like something worthwhile
Old July 7th, 2013, 11:32 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Old July 7th, 2013, 11:53 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Cool thanks. I guess that's about what I pictured, but it nice to see.
Rear axel breather tube Raz Defender Technical Discussions 4 May 10th, 2012 01:18 PM
ARB RD56 air leak cgalpin Defender Technical Discussions 9 May 3rd, 2012 02:42 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
