Air in Fuel System -- How do you check? - Defender Source
Join the Defender Source Community Today
Old September 5th, 2016, 03:17 PM
Bayonet16's Avatar
Bayonet16
1984/110
I have a very tired 2.5 NA with low compression in cyl #1 @40%; all others @ 80%. I have not had time to change the motor back to the 300 tdi that's sitting in my garage. I am going to put that, a new tranny and a new xfr case in, but I won't have time to do that until the holidays. I still want to drive it 5 min to work down hill; then back 10 min up hill;-), but the long cranks are discouraging and I don't want to damage my new starter, or get stranded.
The motor takes a while to start -- about 20 seconds of cranking. Even when I stop momentarily and then try to start it again, it takes a while (engine at normal operating temp). Not 20 seconds, but about 10-15. I assumed it was because of the low compression, which may is probably a contributing factor, but it runs fairly well when warm.
I'm suspecting air is seeping into the lines when I cut the engine off. I replaced the fuel lines when I installed the motor, so I think they're leak free. Now I think it might be the lift pump (condition is suspect) is allowing air in the system. I could replace that cheaply enough ($27 on ebay), but is there some type of test I can conduct to confirm? Heard you could temporarily use clear tubing to see the diesel retreat back into the tank?
Old September 5th, 2016, 03:42 PM
When did you last check your lift pump and sedimenter?
It cannot hurt to replace the filter.
Don't let it run low on fuel.
http://www.defendersource.com/forum/...ons-46387.html
Old September 5th, 2016, 06:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You can disconnect the feed line at the tank and plug it on the tank side.
Then connect a 12V fuel pump with the inlet in a fresh can of diesel and the output the source line from the tank.
Any air leak will become a fuel leak when the 12V pump is on.
RDavisinVA
Old September 7th, 2016, 12:31 AM
Bayonet16's Avatar
Bayonet16
1984/110
So, I don't have a sedimenter, I let it run low on fuel and I don't know how to check the fuel pump. Guess that's three strikes...
The good news is that it runs the same before and after the low fuel incident -- poorly.
Old September 7th, 2016, 01:03 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
It's been a while since I had a 2.5NA in my truck but the procedure is to open the banjo bolt on the fuel filter and prime the lift pump manually with the little lever on the bottom or have a friend crank the starter to do the same.
I would put my money on a bad lift pump. Second thing would be a leak at the fuel filter housing.
Here's a video of Brian Hall bleeding my fuel system on my three hundy at the fuel filter banjo bolt as I cranked the starter. My air problems turned out to be a leak at the sedimenter and a faulty lift pump. Replaced sedimenter with one of Robert Davis's and replaced the lift pump and re-bled and all was well.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 7th, 2016, 08:33 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Chris:
Glad your 300TDI is running fine.
Ed:
The 2.5 N/A has fuel routing that prohibit the type of easy start up the 300TDI can have.
On the 2.5 N/A the return line is routed back into the fuel filter which recirculates trapped air and prevents the engine from starting and after it does prevents it from running properly.
In our shop we get rid of the sandwich filter and install the following:
Tank -> sedimenter -> 12V fuel pump (without any filter - some of them come with a small filter) -> engine lift pump -> spin-on fuel filter (replaces the sandwich filter) -> IP -> return line joins with the spill over line and goes directly back to the -> tank.
Result is a self bleeding fuel system that will deliver enough fuel for that 2.5 to almost get out of its own way!
Good Luck...
RDavisinVA
Old October 2nd, 2016, 08:37 PM
Matt_110's Avatar
Matt_110
Matt
110
Selfishly reviving this thread. I think I found the culprit to my delayed/non starting issue. A rodent has chewed up one of my spillover lines (2.8 TGV). Any recommendations on sourcing one piece vs the entire assembly? I think it's 8mm ID. Thank you
1987 110, 2.8TGV, ZF Auto
fuel
Time for new bushings or brake system check? samer0214 Defender Technical Discussions 6 October 23rd, 2015 02:31 PM
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
If you or your kids have a WII video game system TravelerBT Misc. Chit-Chat 1 January 12th, 2009 12:53 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
