air filter housing o-ring RRC3746 - Defender Source
Old December 19th, 2013, 12:02 PM
jafir's Avatar
jafir
Jafir Elkurd
So I have my air filter housing out while I was running my power steering lines. I noticed that the seal/o-ring has seen better days.
It looks like it is supposed to be part number RRC3746, but that is NLA as far as I can tell. This is on a 2.5NA
Do I just not worry about it, and make do without it or with whatever chunks will go back in, or is there some alternative? I know it's not a huge deal because the filter seems to seal to the upper part of the housing where the intake tube connects, so it shouldn't be an issue of dirt getting into the engine, this seal is just for the two parts of the housing.
Old December 19th, 2013, 12:09 PM
Don't you love how one project turns into another. G-d bless these trucks!
Old December 19th, 2013, 12:13 PM
It does not do much unless you had a snorkel. You could make one with an o-ring kit, or use weather stripping, or silicone if you wanted.
Old December 19th, 2013, 12:17 PM
jafir's Avatar
jafir
Jafir Elkurd
I'm having better luck with this one than my LR3. I got a new update for my scan tool that allows it to work on newer land rovers, and I flashed some of the computers with good success. Then I flashed the transfer case control module..... and now it's forgotten everything it once knew. And they scanner does not have a calibration routine for this. (yet, I hope)
I might be driving the 90 for a few days, just so I don't risk damaging anything.
------ Follow up post added December 19th, 2013 11:18 AM ------
No snorkel.... YET.
I won't worry about. Thanks!
Old December 21st, 2013, 05:26 PM
I just ripped the same o ring and I need to replace it too. Any luck finding one?
Old December 21st, 2013, 05:32 PM
jafir's Avatar
jafir
Jafir Elkurd
Some of the places in the UK show it, but I don't know if that really means they can get it or not. I just google the part number and some sites came back. I may put it on an order if I order some other stuff and see what happens.
Old December 21st, 2013, 05:35 PM
Have you tried a hardware store? Any idea what the actual size is, I'm not near my truck right now.
Old December 22nd, 2013, 07:41 PM
I found a big o ring in the o ring bin, been living happily ever after since
Old December 23rd, 2013, 09:26 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Mcmaster has every size of o-ring you can imagine.
I got one for my air filter housing there a few months ago.
Cheers
- Charles Eames
Old January 8th, 2014, 01:02 PM
Amazon O Ring Linky
27 days shipped but it fits perfectly.
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
Air Filter Housing mgrgpg Defender Technical Discussions 1 December 20th, 2003 01:48 PM
