Air Filter Housing Dust Valve - Defender Source
Old December 12th, 2014, 12:42 PM
D90884's Avatar
D90884
Jon
1994 Defender 90 #884
My 94 NAS D90 is missing the dust valve that is supposed to be on the bottom side of the air filter housing. I tried the usual avenues to find a replacement (including a LR dealership and aftermarket retailers) and it seems this part is no longer made or sold. What have others done to get around this. I have a mantec snorkel on the truck, so it seems counterintuitive to leave it as is. Any advice on whether sealing this up (and how to correctly do so) or where to find a replacement is appreciated.
Thanks.
Old December 12th, 2014, 01:16 PM
A piece of bicycle inner tube?
Originally Posted by pendy
I'm here for the D's
Old December 12th, 2014, 01:26 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Pictures?
Old December 12th, 2014, 01:45 PM
NTC3751? Not available anywhere? Maybe you can use the TDI one, NRC8955.
Old December 12th, 2014, 01:59 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Indeed NTC3751--- and I talked to you this morning. Was Paul not able to help?
Old December 12th, 2014, 02:02 PM
D90884's Avatar
D90884
Jon
I emailed Paul and unfortunately he didn't have one. Thanks though. Seems to be a simple part, but limited availability for sure.
Old December 12th, 2014, 02:05 PM
Just visit any junk yard then. Any Disco 1. The junk yards are full of them.
Old December 13th, 2014, 05:53 PM
D90884's Avatar
D90884
Jon
Thanks for the suggestion on the junk yard. I tried 6 local yards and nobody had a discovery 1. Was able to locate one with a p38 Range Rover and a discovery ii and I was able to piece something together from rubber grommets in those engine bays. Thanks again.
Old December 13th, 2014, 06:09 PM
Dust valve ?
Have always heard that referred to as the "dump valve" where water escapes which is why they are positioned @ the lowest point on the intake. Problem with them is that as they age they tend to open which allows water in easily when wading.
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Air Cleaner Dust Valve Cory Wanted 3 January 4th, 2010 10:33 PM
Need Purge Valve for Air Filter Box taoseno Wanted 0 September 10th, 2009 02:27 PM
200 Tdi air filter housing bracket Uncle Douglas Wanted 9 October 17th, 2008 01:21 PM
Air Filter Housing mgrgpg Defender Technical Discussions 1 December 20th, 2003 01:48 PM
