Air filter for 2.8 HS TGV engine - Defender Source
Old April 19th, 2008, 02:59 PM
Santiago
Santiago Gigola
Hi,
Igot my 2.8 HS International TGV engine connected to a standard LR Defender Td5 air filter (square and relatively small). I have been told on a couple of occasions that this air filter is too small to cope with the air demand of the 2.8 engine.
Anybody has the answer for this?
I have checked the factory air filter that came with the Ford Ranger pickup that was produced with the same 2.8 engine a couple of years ago (in Argentina) and the air filter was much bigger and cilindrical, it has aproximately 80% more surface area.
Any opinions?
During hot days (?) I have the sensation that the engine cannot suck enough air, making a strong vacuum-like noise.
What air filter are other 2.8 HS TGV powered Defender 90 users using?
Regards,
Santiago
Old April 19th, 2008, 06:42 PM
My kit from M and D engineering in the UK came with the 300 tdi LR stock air filter assembly. I use 300 tdi filters as replacements. I would go with that if I were you.
Old April 20th, 2008, 02:50 PM
Santiago
Santiago Gigola
Mark,
Good data. Thank you.
That makes me wonder whether it is worth changing the air filter at all since the Td5 engine was a bit more powerful than the Tdi (aproximately 135 vs 110hp), therefore I imagine that the air demandfor the Td5 would not be less than that of the Tdi. Does this make sense?
Maybe just using the K&N air filter for the Td5 engine would give me a bit more breathing at high revs?
Are K & N filters popular among off road enthusiasts in the US? Are they good for drinving in dusty roads?
Regards,
Santiago
Old April 22nd, 2008, 03:05 PM
Michael
Michael
Discovery 1998
I am no expert, but for dusty conditions use a stock air filter - it will catch smaller particles IMHO.
Old April 22nd, 2008, 08:44 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Is your exhaust restricted?
legend in my own mind
Old April 23rd, 2008, 07:45 AM
Santiago
Santiago Gigola
I have the original Td5 exhaust, I guess it should be OK.
By the way, what air filter do you use for your 2.8 engines Pendy?
Old April 24th, 2008, 09:35 AM
ditch the K&N and go original paper. K&N's are not good for diesels.
Old April 24th, 2008, 08:45 PM
Santiago
Santiago Gigola
Thanks Overlander, I will.
I was recently given the same advice by the guys on the English forum.
Cheers,
Santiago
Old September 19th, 2008, 04:13 PM
discotdi
Todd Miller
Land Rover
why are the K&N filters not good for diesels?
Old September 19th, 2008, 09:30 PM
Too porous. Diesels need very fine filtration.
Old September 20th, 2008, 02:24 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I've run a K&N on my 200tdi for the past 8 years with no problems. The engine oil stays clear for miles and miles after an oil change.
Mike Hammond
engine
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
