Air Filter DIY - Defender Source
Old March 24th, 2009, 09:10 AM
GBX
Jason
'97 D90
Air Filter DIY
Just bought a k&n air filter for my '97 D90. From looking at the engine diagram, it looks like i have to install it from under the car. Is this an easy install? Does anyone have a DIY for replacing the air filter? If not, can someone walk me thru the steps? Thanks!!!
Also getting the NPR rear exhaust installed on my D90, since my stock exhauts just rusted out. Can't wait to get everything installed!
Old March 24th, 2009, 09:42 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Is the air intake not on the firewall in a '97?
Jimmy Buffett
Old March 24th, 2009, 09:46 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Troll Alert!
Old March 24th, 2009, 10:09 AM
Look for the canister with the trumpet part attached to the firewall... Undo the latches and then unscrew the bolt and pull the air cleaner out, install the new one and reassemble.
Old March 24th, 2009, 10:19 AM
artm
Arthur Maravelis
97 SW
Originally Posted by GBX
... it looks like i have to install it from under the car. Is this an easy install?
From under the car it is not an easy install. In fact I doubt you can do it without removing the engine. So, you're looking at a full day's job. Luckily, you only need to replace the air filter once in 100K miles so that's a plus to some degree.
Old March 24th, 2009, 03:05 PM
GBX
Jason
'97 D90
Thanks!
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Purolator Air Filter roverboy For Sale - Parts 2 November 15th, 2005 07:57 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
