Air conditioning switch??? - Defender Source
Old March 29th, 2014, 10:31 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Here it goes! Ok, I have a 97 NAS D90. Back in 1999 she had a catastrophic fire in the fuse box that ended up burning/totaling the 90. We got her all restored sometime back in 2001. When we got it fixed we did not replace the A/C unit in the interior. The AC pump however is still on and all the lines are still hooked up. So the only thing I think I'm missing to activate the AC is the switch, right? Do you think I could activate it and have AC air blowing threw my defrost and floor vents? Thanks in advance!
Old March 29th, 2014, 10:45 AM
hmm. the AC doesn't blow through your defrost. That's the heater duct which is a separate unit. You only get AC through the AC facia vents. To answer your question - it depends on the condition of the fascia unit and the wiring harness. it's not clear to me if you're is damaged or not.
I had to replace my whole harness for mine due to a fault. I have some spare's I'd sell if you need them. switches, AC ECU, the old harness that you could cut sections out of to replace damaged ones.
You need to test your compressor to make sure the clutch still works (single wire on the compressor) and if the AC refrigerant lines where ever opened due to the fault, you would obviously need recharge after replacing the drier. but I would start with testing the harness to make sure everything is operational.
Mark Kellgren
KM4BOR
Old March 29th, 2014, 10:57 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I do not have a facia. Do no AC for me it sounds like. Anyone know if I can get a belt to bypass the pump?
------ Follow up post added March 29th, 2014 09:57 AM ------
....So*
Old March 29th, 2014, 11:24 AM
Pics...
Old March 29th, 2014, 11:42 AM
well it's easy enough to add. if you have the compressor, that's half the cost right there. time to time folks on here sell components. Ron probably has 3 complete AC units on his guest bathroom sink right now.
Mark Kellgren
KM4BOR
Old March 29th, 2014, 01:11 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Ok, the AC facia add on is so big and bulky though. So I cannot have AC blowing through the feet or defrost vents? I figured if I switched he AC pump on and turned my system to "cold" it would be AC air blowing through. I will post a pic in a little bit. All it is is a normal NAS dash with no AC add on.
Old March 29th, 2014, 01:41 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Ohhh ok, that makes sense! So the evap coil is the coil that becomes cold to cool the flowing air correct?
Old March 29th, 2014, 02:27 PM
Videoguy
Ron
1997 Defender 90 SW
AC
All 97 D90 came with a compressor regardless of whether the interior unit was installed. You cannot run a 97 without the compressor installed unless you can find a special belt.
Air Conditioning Floridadan Defender Technical Discussions 6 November 9th, 2005 08:12 PM
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
Air Conditioning azdefender Wanted 2 March 8th, 2004 01:41 AM
