Air Conditioning "Screetching" Sound? - Defender Source
Old June 30th, 2014, 12:07 PM
ssi19's Avatar
ssi19
scott
1995/D90
When I turn on the AC, I have developed a real loud screeching sound under the vehicle (almost like the fan or a belt is rubbing against something). Only happens when the AC is on, and not every time (about 8 out of 10 times when I turn it on). Data point: sound remains constant even if I increase or decrease speed of the fan. Anyone ever had this issue? Really loud - can't be good. 1995 D90.
Sorry - moderators, can this be moved to "Defender" section? Thanks
Old June 30th, 2014, 12:23 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Compressor clutch?
Old June 30th, 2014, 12:29 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by ssi19 View Post
When I turn on the AC, I have developed a real loud screeching sound under the vehicle (almost like the fan or a belt is rubbing against something). Only happens when the AC is on, and not every time (about 8 out of 10 times when I turn it on). Data point: sound remains constant even if I increase or decrease speed of the fan. Anyone ever had this issue? Really loud - can't be good. 1995 D90. Sorry - moderators, can this be moved to "Defender" section? Thanks
Sometimes the belts stretch and slip on the pulley. It's not noticeable, it will still turn but it will make a squealing sound. You should be able to adjust the tensioner or replace the belt to resolve the issue.
Old June 30th, 2014, 12:55 PM
does the AC actually work? (besides screeching)
Old June 30th, 2014, 01:02 PM
ssi19's Avatar
ssi19
scott
1995/D90
yes works perfectly actually.
Old June 30th, 2014, 01:18 PM
screeching could be the belt isn't tight enough or the compressor is failing and is harder for the engine to drive causing belt slip ... mine experienced the second and AC still worked fine ... it did raise the temp on the engine as it had to work harder ...
Old June 30th, 2014, 01:39 PM
If the AC works, then my experience has been that the issue is poor belt tension (or the AC compressor is loose)
Old June 30th, 2014, 06:12 PM
ssi19's Avatar
ssi19
scott
1995/D90
Ok. Sounds like I gotta bring it in for some work. Thx all
Air Conditioning Floridadan Defender Technical Discussions 6 November 9th, 2005 08:12 PM
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
Air Conditioning azdefender Wanted 2 March 8th, 2004 01:41 AM
