Air Conditioning Problem - Defender Source
Old April 27th, 2008, 12:55 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I just wanted to double-check with everyone on my AC problem before proceeding. My AC works when the engine is cold, but once it warms up it kicks off. The Compressor works of course, as does the electric fan in front of the radiator. The motor seems to cool just fine. So am I correct to assume it's that temp cutoff switch on the thermostat housing? And is this a readily available part? Is it hard to get out?
My next step is to get the motor warmed up and try to bypass that switch to verify.`
Semper Fi!
Old April 27th, 2008, 01:48 PM
I don't know if the 94 AC takes its temp signal from the computer or just from a switch, but you're on the right track with the diagnosis. Its an of/off thing with the switch - IIRC, the natural state is +12v, and a lack of voltage shuts her off.
Old April 27th, 2008, 03:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
(stalkervoice)You really didn't need it in Shirlington this morning, did you?(/stalkervoice)
Old April 27th, 2008, 03:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
Good thing I was packing heat you sicko!
Where were you and why didn't you say hi?
Semper Fi!
Old April 27th, 2008, 04:06 PM
Abrooks's Avatar
Abrooks
Tony Brooks
We were having brunch at Carlyle, watched y'all walk by. If I hadn't been knee deep into filet and poached eggs, I would've run out. What brought you up to the barrio?
Old April 27th, 2008, 04:24 PM
Wolf Fabrication
Sterling Archer
'08 D3
We LOVE the Carlyle. We decided the try the brunch this time. I had the steak and eggs benedict. Wasn't too impressed, although I am not a heavy breakfast kinda guy. Wife loved the french toast though.
Hey, what am I doing changing the subject of my own post?
Semper Fi!
Old April 27th, 2008, 05:08 PM
Abrooks's Avatar
Abrooks
Tony Brooks
No shit, I had the same thing and was also unimpressed. I thought the meat was flavorless, the eggs were only warm and whatever that bread was under it all was burnt. That said, that was one mediocre meal out of the hundreds I've had there. Luna is always a winner, too.
I've no idea what's wrong with your AC.
Old April 27th, 2008, 05:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
Funny, you described my breakfast perfectly! We must of had the same chef. I'll stick with lunch and dinner next time.
Semper Fi!
Old May 6th, 2008, 10:15 AM
Wolf Fabrication
Sterling Archer
'08 D3
So I finally had a chance to check under the hood. I found the temp switch on the thermostat housing and with the vehicle running (cold) and the AC on the fan and compressor turn and the AC is cold. When I unplug the two wires from the switch they of course stop. So I ran a jumper across the two wires and after the engine warms up the the AC does not work and the compressor does not turn. Am I checking the wrong temp switch?
Semper Fi!
Old May 6th, 2008, 10:58 AM
On the Tdi, the AC uses its own temp switches, can't say for sure on the V8. On the 97 it takes it's temp signal from the ECU.
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
