Air Condenser Install ? - Defender Source
Old December 8th, 2011, 01:15 PM
bjp
Brent
1995 D90
I am trying to a attach a condenser into 1995 D90.
Main question is how do I mount the lower bracket underneath the radiator pin on the bottom radiator frame mount? Do I need to lift the radiator up a few inches and slide the hole in the bracket underneath the pin and lower it back down. If that is how it is done, can i do it without removing the radiator hoses and oil lines? Do the rubber grommets on top of the radiator bracket and under the radiator pins slide off? Do I need to remove fan shroud? Do you relocate the horns somewhere else?
Thanks for your help.
ID:	44528   Click image for larger version
Old December 9th, 2011, 03:11 PM
bjp
Brent
1995 D90
Any Pointers? Going to try and do it tonight?
Webasto Air Heater Install ideas... tjfslaughter Defender Technical Discussions 10 October 28th, 2011 12:51 PM
Mantec Raised Air Intake Install Pics chris snell Defender Technical Discussions 30 March 8th, 2010 01:50 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
ARB air lockers install mhansen Defender Technical Discussions 1 December 29th, 2003 11:38 AM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
