Air Box lower openning ?????????? - Defender Source
Old May 19th, 2010, 08:18 PM
Rugbier's Avatar
Rugbier
Gustavo
Can anyone tell me where the hose shown on the picture ( to the left of the number 12 ) goes to? and what is the part number for said pipe?
My 110 does not have it at all.
Name:	Air filter housing.JPG
NO SIGNATURE
Old May 19th, 2010, 08:27 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I don't think it is a hose, its just the same rubber piece that is shown on that opening int he photo above. Its designed as a drain, to let water out that gets into the assembly. I think the only difference is that the drawing is cut off on the bottom rendition, making it look more like a hose..
~Scott T.
'95 D-90 ST - AA Yellow
Old May 19th, 2010, 08:30 PM
Rugbier's Avatar
Rugbier
Gustavo
I have nothing but a nub where something is suppossed to go.
Now my question since that is low, what would the purpose of my snorkel be? , I mean wouldn't water get into the Air Filter through that openning?
Can it be plugged? Any consecuences from plugging it?
NO SIGNATURE
Old May 19th, 2010, 08:34 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
It has a little rubber nipple on it with a slit to let water / oil out, when you are sucking air in the slit seals so water should not be sucked up into the intake.
If you seal it there is a chance that you could gather water or oil in the filter housing, without the rubber nub bit you risk sucking water
just happen to have the page with the part number printed and sitting on my desk
NRC8955
http://www.lrseries.com/shop/product...UMP-VALVE.html
http://www.thexmod.com/item_detail.asp?id=828
Old May 19th, 2010, 08:42 PM
Rugbier's Avatar
Rugbier
Gustavo
Dave,
Thank you
Now I will bug the shit out of George ( RDS ) tomorrow about this part
NO SIGNATURE
Old May 20th, 2010, 10:23 PM
no personal expereince but I have always read that needs to be properly sealed when going into deep water. I would not risk it any other way. it is really just to drain dust out of the filter housing
Old May 22nd, 2010, 11:11 PM
as Dave pointed out its called a dump valve. An expanding type freeze plug from any auto parts store will cure the hole. As RenChing pointed out these things suck and as they age harden the two flaps tend to open-ie ceate a hole that sucks water in.
Old May 23rd, 2010, 02:45 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I plugged mine years ago and have never had a problem.
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
