Age old Heater motor question - Defender Source
Old September 28th, 2010, 07:21 PM
skupetz
Gustaf Kupetz
NAS110, HCPU, Disco, Toylander, 2
Hey,
The Heater blower motor has bit the dust in the 110. Does anybody have any bigger motor ideas or fixes to make it shove more air at you? other wise I'll just order stock....
Thanks in advance!
-Gustaf
Old September 29th, 2010, 09:13 AM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
Remove the dash and cut the hole bigger. Remove the heater core and repack with new foam so that only hot air enter the cab.
Old September 29th, 2010, 09:21 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
High efficiency core will help. Using a snow-cover will help keep the new motor running longer if you're in an area where you're pulling ice/water through it all the time. A secondary core mounted under the passenger seat will do wonders, they're cheap and available through places like Summit.
To improve flow you can always add booster fans to the ducts but the stock layout isn't great, it's one of the reasons I'm designing a dash from the bulkhead out, the stock system is far too restrictive and adding more blower just makes it work harder, the high-efficiency core is better with the stock heater because you end up with hotter air rather than just trying to force more of it through.
Old September 29th, 2010, 11:54 AM
skupetz
Gustaf Kupetz
Heater question
Hey thanks guys,
Pretty familiar with all the rover tricks to get more heat... I was just curious if there was a "Known" larger heater motor to put in.
-Gustaf
heater, motor
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Heater hookup TDI Guy Defender Technical Discussions 27 April 19th, 2005 03:16 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
