aftermarket temp guage options - Defender Source
Old January 3rd, 2005, 11:53 AM
draaronr's Avatar
draaronr
Here
LR3
Mine isn't reading correctly. I have replaced the temp sender but that hasn't helped. So I assume it must be the guage, any options out there.
Old January 3rd, 2005, 02:25 PM
I think everyone goes with the VDO's as they look the closest to stock. You can get them at
http://www.egauges.com/
And a little info on them here
http://www.defendersource.com/faq/In...ents.html#Temp
Old January 3rd, 2005, 03:58 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I went with an aftermarket analog gauge and sender. Basically a really long thermometer. Found it at Jegs.com. Not pretty, but I get exact degree readings from the hot side of the radiator.
Old January 3rd, 2005, 04:21 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Aaron, if you can wait a month or so, I'm going to be putting in VDO gauges and you can have my stocker.
Old January 3rd, 2005, 09:22 PM
draaronr's Avatar
draaronr
Here
LR3
Thanks mike I think I will go with that route. I appreciate it Ken I just need to know the temp I just did a rebuild on the motor, with a bunch of parts from RPI so last thing I want is a meltdown.
Old January 3rd, 2005, 11:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I don't know if it was just mine but the stock temp guage read nothing close to the actual temp. I think it is a good idea to upgrade to a decent sender and guage.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 4th, 2005, 01:51 PM
draaronr's Avatar
draaronr
Here
LR3
Mike I contacted e guages and the no longer have the part # 323-422 which is a 5/8-18unf, all they have is 1/8 27NPT. do you know where to find an adapter.
Old January 4th, 2005, 02:33 PM
Aaron, check out this post by Daves S.
http://www.defendersource.com/forum/...0&postcount=26
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
lousy aftermarket wheel options huck1974 Misc. Chit-Chat 9 March 13th, 2007 07:27 AM
Temp Guage Position willtillery Defender Technical Discussions 1 October 15th, 2005 05:11 PM
Aftermarket distributor options. draaronr Defender Technical Discussions 1 September 29th, 2004 07:30 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
