aftermarket fuel filer - Defender Source
Old February 28th, 2005, 03:43 PM
jabber
m j
110
Does anyone have any thoughts on aftermarket fuel filters... I was primarily thinking of the small "coffee can" type.... Mounting it under the hood up and out of the way?
Old February 28th, 2005, 03:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Well, Fram does make a replacement for it that is easily available around here. Moving the location wouldn't be hard, just put in a short section of steel line where it is now, and splice it in wherever you want.
-Hans
My oil line fix
My 100k stopped odometer fix
What is wrong with the stock one? They sell cheap ones at Walmart.
Old February 28th, 2005, 04:58 PM
Napa Gold
is the location on the frame rail not good? I have never in all my years of Defenderism never heard of someone damagin th fuel filter??
Old February 28th, 2005, 05:42 PM
jabber
m j
110
Just curious... Those aftermarket canister types are pretty cheap too. I was just thumbing through a summit catalog and wondered if anyone had done something like that.
Cheers,
MKJ
Old February 28th, 2005, 07:45 PM
Hans's Avatar
Hans
Hans Haase
With anything in the Summit catalog, you have to be VERY VERY careful. The fuel pump probably puts out around 75psi or more, and will literally pop most of the filters that summit carries.
Those are usually only made for 4-6psi in a carb setup, EFI is a much higher pressure beast. Stick with the proper parts in this case.
-Hans
My oil line fix
fuel
» Defender Registry
Red
KGH
NAS 110
Pugsly
Add your Defender
