adwest ntc8223 manual steering box bolt size - Defender Source
Old June 13th, 2015, 09:29 AM
This shouldn't be hard, but i can't figure out the right thread size for the bolts that mount my steering box to the frame.
The steering box is an adwest, with the label showing
adwest eng. ltd. England
ntc 8223
date code serial no
3 - J - 0997
The manual says ntc8223 is a gemmer and it needs bolts
4 x BH607381 (7/17 20) up to vin 323657
or
4 x BX112201 (m12 1.5) from vin 323685
I have run a tap of both sizes through one of th holes and neither one jumps out at me as being the better fit. Since this is the steering I really don't want to F this up.
Of course I have no idea what the serial # of the truck is that this came from since I bought it used. Any thoughts? Am I making too much of this?
Originally Posted by pendy
I'm here for the D's
Old June 13th, 2015, 09:52 AM
clay has the bolts
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 13th, 2015, 10:06 AM
I just ordered both, but sent him an email anyway, thanks!
Old June 14th, 2015, 09:29 PM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
My '87 110 had the M12 x 1.5 120mm long. They are bolts with nuts so the most important thing is the hardness and the length.
Old June 15th, 2015, 10:10 PM
Mine has threaded holes in the box. I ended up saying F it and buying both. I can use the other four to mount the center crossmember.
manual
Size of bolt on the bottom of the undside steering column shroud? bradfordish Defender Technical Discussions 6 February 7th, 2014 12:50 PM
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
steering stop bolt size? ini88 Defender Technical Discussions 1 September 13th, 2007 06:47 AM
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
