Advice on replacing TDI300 Turbo - Defender Source
Old January 29th, 2008, 06:59 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Hi All
I plan to replace the turbo on the 300tdi this weekend.
Question, do i need to use any kind of sealant when I fit the new turbo into the manifold or would the heat simply cause both parts to fuse together snugly?
Regards
Old January 29th, 2008, 08:36 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Originally Posted by Eddie 1
Hi All
Regards
Hi Ed, I had mine on the 200 tdi rebuilt and if it anything like it I would suggest before changing them, try to have studs and all metal self locking bolts for it as well as new metal compression gasket. You will most likely need heat and penetrating oil to have the bolts come out. Otherwise it is pretty straight forward.
Good luck !
Pat
Kirk Lazarus, Tropic Thunder
Old January 30th, 2008, 08:32 AM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Thanks Pat!
I got new bolts (the blacks ones). I have a new pair of the C clamps.
I plan to take it to the machine shop to extract the old turbo out of the manifold.
Question: What is the metal compression gasket you're talking about?
Is it the gasket between the manifold and cylinder head?
Regards
Old January 30th, 2008, 09:22 AM
Retrofit's Avatar
Retrofit
Pat
Regards
Its the one between the turbo and the engine exhaust manifold and between the turbo and its exhaust manifold. But this was on the 200 tdi, it might be different from the 300 tdi.
Pat
Old January 30th, 2008, 09:48 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Just checked the 300tdi shop manual which says that you'll need new manifold and exhaust flange gaskets and a new clip to connect the control lever to the wastegate spindle.
I've never done this but I have the manual... (yipee for me)
Old January 30th, 2008, 12:09 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Thanks for the info guys!
Old February 1st, 2008, 09:52 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Be very careful you don't have the oil return line kinked or compressed after you put in the new turbo. I used to rebuild turbos and saw a lot of failures due simply to the fact that the return line was restricted.
While you're at it, I'd relocate your oil pressure sending unit to the turbo. Longer life comes from making sure your oil pressure is good at the turbo before driving.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 1st, 2008, 01:22 PM
Eddie 1's Avatar
Eddie 1
EDWARD BAHAW
Disco 1 TDI 300 SE
Thanks for the advice!
ac, tdi
TDI 300 Turbo Advice Eddie 1 Defender Technical Discussions 9 March 13th, 2007 05:22 PM
Replacing Cantrails, need advice! Harrisonml Defender Technical Discussions 0 October 7th, 2006 07:50 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
