Advice on how to get 2nd fuel tank filler location to look stock. - Defender Source
Old January 14th, 2012, 10:16 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
So I am about to pull the trigger on this project. I have had an annoying dent on my passenger-side tub quarter panel since I bought the truck, just about exactly where one would put the 2nd fuel tank filler location. Just my luck, right? Except that I have done a lot of research on installing the Aux tank and found that the best option, just sending the truck to ECR, isn't really financially feasible unless I'm justifying the trip across the country by doing alot more. And I'd love to do more to the truck, but that too is also not financially feasible at this time. So how should I go about getting this project to come out right? Any advice would be much appreciated. Below is a picture of how I'd like the fuel filler to look (ie. with a rounded top) just like my other fuel filler cut-out. Next to it is my truck, currently with the dent in it, followed by a close-up, that I believe would be resolved with the new Aux Fuel tank filler cutout. Thanks again! - Dave
ID:	46140   Click image for larger version
Old January 14th, 2012, 11:32 PM
It is possible to use a single filler by taking off the stock filler pipe and welding a Y piece into it and running a hose to the second tank.
Old January 14th, 2012, 11:38 PM
D90Overkill
David Frank
1995 ST #2615
Good idea, but I would still have that dang dent! :-(
That IS a great idea and alot easier to install and to fill. I was just trying to get rid of that dent without a brand new tub panel or bondo. I did see a new right-side tub panel on this site recently for a great price though!
Old January 15th, 2012, 12:24 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Just because you have a small dent doesn't mean a fuel filler will make it look better. I don't think the dent is that bad but it is personal preference. I am looking at adding 2 tanks under the seat boxes and wouldn't cut a whole in the side but would manually fill it up from inside the seat box. John is right, and I have seen a y pipe to fill the aux tank from the original filler, but I don't know how feasible it is with larger tires under full articulation. Seems to me, anyone running a bit larger tire might hit that pipe. Don't know for sure.
I'd like to see photos of options.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 15th, 2012, 01:37 AM
Getting the radius in the aluminium seems near impossible to me. Also, on the grey one, it seems to have been panel bonded as there are no spot weld divets. I am sure you could do a passable job, but I would think you would want to fill under the seat. Keep in mind, the filler pipe may interfere with the w bar for the cage.
Old January 15th, 2012, 08:53 AM
discojosh2000's Avatar
discojosh2000
Josh
1995 Black ST
I have some aux tank filler neck mounts. I can post pics Monday.
95 D90 Black ST
06 LR3 Black
10 Range Rover
Old January 15th, 2012, 12:16 PM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
Genuine fuel filler from the Hi-Capacity pick up Defender models uses a plastic version insert that would be easy to fit and give a factory look. Pics of it can be seen in this thread http://www.defender2.net/forum/topic6071.html
Old January 15th, 2012, 12:34 PM
D90Overkill
David Frank
1995 ST #2615
Thanks for suggestions thus far.
Thanks all. I was hoping to do the radius in the aluminum panel but the Hi-Cap plastic filler insert that you referrenced does make life a bit easier. I just love the way the radius filler cutouts on the tub panel in this 90 pic look much like footholds on the side of an aircraft. I was hoping for the same look.
ID:	46144   Click image for larger version
ID:	46146   Click image for larger version
Old January 15th, 2012, 12:45 PM
D90Overkill
David Frank
1995 ST #2615
Torch and a Hammer. Well, it does need a paint job! ;-)
I know a guy here in Northern CA who can repair that dent without replacing the panel or bondo. It would need to be re painted as the technique he uses requires a torch and a hammer.
-Jeff
Thanks. That could work too! Where is he located? I'd like to know how much that would cost, minus the paint of course. Is it a body shop or someone's personal garage shop? Then I could just go with the "Y" adapter and make fuel ups easier!
Old January 15th, 2012, 06:34 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I have absolutely nothing constructive to add to this; just wanted to say that 90 is amazing. Wow. And interested in this topic as well...
Old January 16th, 2012, 12:18 PM
discojosh2000
Josh
1995 Black ST
Here is what I have to mount the filler neck with an aux tank.
95 D90 Black ST
06 LR3 Black
10 Range Rover
Old January 16th, 2012, 12:42 PM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
Y pipe filler
I fabricated a Y pipe for aux tank. Very happy with the filling access. No clearance issues with stock tire. http://imageevent.com/jimpace/landro...c79w19.eagle_s
Old January 16th, 2012, 12:53 PM
Do you have a fuel pump attached to your Rover Accessories aux fuel tank?
Have you brought your truck offroad or anywhere, where that passenger rear wheel would need to tuck in/articulate into the wheel well? I know you said it doesn't rub, just wondering under which circumstances it does not interfere.
Old January 17th, 2012, 10:43 AM
oldgreentrucks
Jim Pace
aux tank
Not to hijack but
1.Yes remote 12v fuel pump transfers fuel into main tank.
2.Plenty of articulation situations w/o rubbing.
I think pics of installation posted at link in above post.
For me, one of the best modifications (extended range) to a gas D90!
Jim
Old January 17th, 2012, 10:52 AM
Not to hijack but
Jim
Thanks! Yeah, I have the same aux tank for Rover Accessories, but I think they may be out of business now. I called and left them messages, wrote e-mails, etc. - no answer. I had been trying to track down a copy of the owners manual for it, because I couldn't get it to work. The tank came with my truck and I finally found out that it has a pump, and that pump is dead (found an owners manual to it). My filler neck is tucked into the front-most portion of the rear wheel well, and I've never hit that either. Did you just fabricate this neck so that you'd only have to fill the two tanks via a single nozzle?
Old January 17th, 2012, 12:11 PM
oldgreentrucks
Jim Pace
Y pipe filler
@rijosho
Happy to help any way I can.
1. Any low pressure transfer fuel pump should work.
2. Plumb into main tank vent line (w/ overflow back into aux tank).
3. My brothers D90 aux tank has the filler under the rear fender in front of tire and this is MUCH better. Easier civilized access and no mud.
4. Yes I fabbed the "Y" and the "connector pipe" at a local muffler shop for $20.
Old January 17th, 2012, 12:47 PM
D90Overkill
David Frank
1995 ST #2615
Filler Neck Mounts.
Those are them! They look nice. Is one just painted or are they made from different materials? Are you willing to part with one? Let me know. Thanks again. - Dave
Old January 17th, 2012, 01:14 PM
I noticed the new Britpart catalog has flow through aux tanks for rear tank TD5/TDCI 90s. Could probably be made to work with a NAS truck.
http://britpart.com/Accessory-Catalo...px?AccRef=3435
Old January 17th, 2012, 04:58 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Does anyone carry the wheel well aux tanks any more ? (Tired of only getting 180 miles per tank , the drive to work and back everyday alone is 42 miles)
Chris "V"
Old January 18th, 2012, 09:23 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Another way of doing it.
I'm pretty sure I've seen small hi GPM fuel transfer pumps (on the order of 20gpm) that could be used to fill the aux tank from the main tank as you fill it. So with that and two 3-way valves you could either draw from the main to fill the aux or vice versa to get the fuel back to the main tank.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
fuel, fuel tank
'84 300 Tdi 110 Fuel Tank Shearpin Smaller Projects 3 September 1st, 2011 09:02 PM
Fuel tank venting Tyler Wirken Defender Technical Discussions 0 January 29th, 2010 06:03 PM
Fuel Tank Skid plate Gore Ranger For Sale - Parts 0 March 14th, 2006 01:22 PM
Dropping the gas tank Gkase Defender Technical Discussions 33 December 1st, 2003 08:59 AM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
