Advice on first time removal of door tops - Page 2 - Defender Source
Old June 26th, 2013, 12:58 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Is GCR still the place to go for stainless studs? I haven't bought a set of studs in almost ten years.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old June 26th, 2013, 01:11 AM
grnrvrs's Avatar
grnrvrs
Paul
88
AB would be my fist stop for SS studs.
1970 SIIA 88, Sold
Old June 26th, 2013, 01:48 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Chris, I ordered up a set this am from AB. 89 bucks for 4 studs with bolts...
Old July 7th, 2013, 03:49 PM
josh-man's Avatar
josh-man
joshua
Just a follow up;
Installed new studs in doors, AB reccomends Loctite on the stainless but I did not do this. They say included in the instructions that stainless has a tendency to vibrate loose but I'm going to beta test this myself.
The studs went in the door tips no prob, however there was so much corrosion on the inside of the door sleeves itself the new studs wouldn't fit. They just needed to be cleaned out. I bet a wire brush (similar to a bottle brush) would have worked but I didn't have anything I could get down in there so I just reemed it out with a drill bit a few sizes smaller to smooth out the inside and the studs slid right through.
The new door seals were ordered from RN as AB doesn't carry them. Couple pictures below.
One issue I notice now is the famous gap between the door weather seal and the door tops is MUCH greater than it used to be. Clearly my door weather seal could use replacing, but curious if anyone ever experimented with a shim of some sort to angle the door top in EVER so slightly??
Cheers,
Josh
ID:	75503   Click image for larger version
Old July 7th, 2013, 04:10 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Yes that has been done. Maybe JimC has a thread that touches on that. I forget how he did it but he angled it in just a bit.
Old July 7th, 2013, 04:40 PM
JimC and I used pond liner to shim in.
Old July 7th, 2013, 04:57 PM
josh-man's Avatar
josh-man
joshua
Tell me more.
Old July 7th, 2013, 04:58 PM
Search pond liner by JimC
Old July 8th, 2013, 12:37 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
The studs won't loosen up over time. At least thats been my experience. I use the foam weather stripping on the tops where they meet the gasket to fill in any gaps. Works pretty well and is cheap.
Jimmy Buffett
Old July 8th, 2013, 01:04 PM
Searched "shim" and came up with this oldie but a goodie:
Shim Thread
Old July 8th, 2013, 01:37 PM
Stick your knee on the door and bend the top over slightly to tighten the gap. No need for shims. The angle of the studs is what sets it.
Old July 10th, 2013, 01:56 PM
josh-man's Avatar
josh-man
joshua
This worked really well. Thanks. I think coupled with replacing the door weatherstrip, it will solve the problem.
advice, door
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
Inconsistent post time bd90 Support & Suggestions 4 December 19th, 2003 08:34 AM
damn heater removal! alternative replacement? artm Defender Technical Discussions 7 October 15th, 2003 09:20 AM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
