Advice on custom legs for my 110 middle seats - Defender Source
Old February 13th, 2012, 08:52 PM
I'm doing some customization of the middle row seats, particularly the legs that the middle row 60/40 rest on. I've replaced the pivots that the legs rotate on in the bracket with quick release pins, and now I want to modify the leg itself (not the part on the seat, but the part that stays on the bracket when you pull the seat). I've confirmed that the legs are 3/4" OD, and clearly steel pipe. The look like they are just about the same thickness as steel EMT conduit. If I make custom legs out of the conduit, would it have the same strength for supporting a seated person as the original legs? Both are steel, same OD and roughly same thickness. I'll get a manual bender to do the 30deg bend on it.
Thoughts?
110, seats
cover seats for 110 ROVERMAN1 Wanted 0 October 11th, 2011 10:25 AM
110 Middle Door Disassembly Wolf Fabrication Defender Technical Discussions 5 August 17th, 2010 10:43 AM
Genuine Seat Covers - NAS 110 - Fronts/Middle 40-60/Rear Jump Seats pcscharfe Wanted 1 June 1st, 2009 04:19 PM
110 Middle Row FLOORMAT - Heavy Duty? STC50173 pcscharfe Misc. Chit-Chat 14 May 29th, 2009 05:02 PM
Jump seats from Defender 110 Mooreland cloth good condition. Set of 4 inboard facing Northface For Sale - Parts 2 August 1st, 2005 05:20 PM
