Advice on chassis and engine conversion project - Defender Source
Old August 12th, 2008, 10:08 AM
Rovermn
Tim Capelle
72 series 3
Ok need a little advice.
Looking to convert a 1967 carawagon series 11a landrover to a coil spring, disc brake chassis and engine.
I see some options out there that I would like your take on. I am not sure if the 2.5 has enough power, etc- Can you give em the pros and cons and your thoughts on the selection with sufficent power, cost and durability in mind? The 200 tdi and 300 tdi seems like a good bet but cost is much higher....
Option 1 Engine
Chassis 2.5 Na diesel with manual tranny
Defender 110
Otion 2
Chassis
Defender 110 3.9V8 with auto tranny
Option3
Buy a RRC LWB 4.2 V8 with auto tranny
Option 4
Buy a 1983 defender and switch cap, tub, etc 200 tdi or 300 tdi
conversion, engine
Rebuild and Tdi Conversion Pix JimC Truck Build-up's & Restores 9 January 10th, 2012 04:58 AM
Custom Chassis Advice? ajh Defender Technical Discussions 7 March 24th, 2009 11:28 PM
Advice on cleaning engine rayfi Defender Technical Discussions 2 October 30th, 2008 02:56 PM
Diesel Conversion Experiences JimC Defender Technical Discussions 10 December 13th, 2004 05:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
