Advice on bleeding brakes - Page 2 - Defender Source
Old March 18th, 2012, 08:18 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Almost wondering if it matters if the calipers are mounted with the bleeders on the bottom or top ? ( could not remember which way they came off if mounted with the bleeder down instead of up would that prevent proper bleeding ?
Chris "V"
Old March 18th, 2012, 09:19 PM
Afaik the bleeder needs to be on top as the air rises.
Originally Posted by pendy
I'm here for the D's
Old March 18th, 2012, 09:23 PM
Do you have drums? If so, sounds like they are not adjusted.
Yes, bleed nipples at top.
Chris Velardi
Chris Velardi
1975 101FC
Sh!t time to un mount and remount ......
------ Follow up post added March 18th, 2012 09:26 PM ------
Drum rear , disk up front ( brakes were ok before replacing sized calipers) ( the rear drums must have been doing all the work.
Chris "V"
Old March 18th, 2012, 11:57 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
I am glad this came up I have bleed mine and I still have that noise of slight air letting out. I bleed them when I lost the slave cylinder for my clutch.
bought new bleeders for the rear used liquid plumbers tape.
new fluid through the entire system.
no leaks inside or outside.
I tried the x pattern
I tried the farthest
I thought the mini's were difficult but wow.
Old March 20th, 2012, 10:21 PM
Chris Velardi
Chris Velardi
1975 101FC
Never use Teflon plumbers tape on brake line threads ( all you need is a good anti size lubricant ( so they wont rust in place. The threads don't do the sealing the line flares ( single bubble , double bubble or cone )
Turned out you must have the bleed screws on top ( on had my calipers on the wrong wheels ( right left so they were upside down. Swapped them power bleed with Motive , breaks are now perfect . Thanks all)
Chris "V"
Old June 21st, 2012, 09:51 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
In the manual that I have it says to bleed the brakes in this order
LF
RF
LR
RR
http://www.landroverresource.com/doc...nual_96_on.pdf. ( page 278)
I replaced my pads and bled the brakes. The pedal is firm but the stopping power is a little lacking. Do the pads need to break in? The package insert claims they need 150 miles but that seems like a lot.
Old June 21st, 2012, 10:30 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
The ebc pads have a specific procedure to break them in. Not sure about the AB ones.
bleed, brake
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Advice Sought... cbass Misc. Chit-Chat 29 March 11th, 2005 07:56 PM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
any advice or comments ccrover Misc. Chit-Chat 6 December 7th, 2003 11:43 PM
