Advice on 3.9l distributor/ignition setup - Defender Source
Old March 19th, 2015, 10:42 PM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
The 2.25l in my 109 is getting replaced by a 3.9l that will be carbuerated. The 3.9l currently has no distributor so I need to source a suitable ignition system. Should I stick with LR parts or look at an after market set up?
"I think we are good...its still dripping"
Old March 19th, 2015, 11:02 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
You need to fit the timing cover from an old 3.5 motor that has a dizzy. You will probably need cam gears and such, too. You can retro fit the modern fuel injected motor with the older parts.
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 20th, 2015, 05:55 AM
d110pickup
Mike Pado
'97 D90 ST #1153
I've used the Mallory Unilite dizzy & coil in the past with very good success. I would certainly still recommend it.
Mike Pado
I'm not saying that stupid people should die . . . but maybe we could remove the warning labels & let nature take it's course.
Old March 20th, 2015, 06:20 AM
What's wrong with the electronic diz? they are pretty darn reliable. They're available for chips.
Old March 20th, 2015, 08:35 AM
ezzzzzzz
Mark Garrenton
I look at a mid seventies Buick V8 HEI (coil in cap) distributor. It runs reliably with only a ground, +12v and tach output. 40kv output and the module in under the cap.
Old March 20th, 2015, 10:35 AM
WildBoar's Avatar
WildBoar
Derek Borror
I am reading what I can online and trying to get smarter on this topic...something of which I have no experience with. I definitely want to keep this simple so I am not sure an electronic ignition is what I am looking for unless I don't understand what the minimum components are for this type of set up. I also didn't think I would need to swap any existing engine components out like cam gears and so forth.
Fleabay has a Pertronix D175520 Rover V8 Distributor 35DLM 8Cyl 3.5L 3.9L 4.2L 2-Pin 1992-1995 - should be the right gearing (according to the accompanying fit chart) and all I would need is a coil right? Unless Pertronix is junk...which I don't even know.
There are also several used 3.9l dizzys for sale...should I steer clear of these?
------ Follow up post added March 20th, 2015 10:37 AM ------
This is going in to my Series IIa...what would this set up look like in this scenario?
------ Follow up post added March 20th, 2015 10:42 AM ------
Would this drop right in or would gearing be an issue? I like the simplicity...isn't a mid seventies Buick V8 a 215? And the Rover 3.9l is just a bored out version of the Buick 215? I am looking at using the intake manifold for a 215 for the carb conversion.
Old March 20th, 2015, 11:16 AM
The 3.9 diz is electronic. Needs only the wire harness that connects it to the coil and ignition amplifier module. It has nothing to do with the engine ECU. However, if you were to obtain the EFI components, engine wiring harness and an ECU, then you'd be golden...allowing you to just run the whole mess with the stock engine management.
Don't poo pooh that option. Gazillions of trucks running around the planet with that setup. It works, is easy to get parts for and is plug and play. In terms of "keeping it simple" this is the obvious choice as there are way fewer moving parts. I don't want to say that carbs are a bad option, but they are given today's electronic engine control.
Old March 20th, 2015, 12:19 PM
WildBoar's Avatar
WildBoar
Derek Borror
Hmmm...well I do have this in the garage. No ecu or harness..or diz.
ID:	116506   Click image for larger version
Old March 20th, 2015, 12:56 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I'm kinda curious as to what kind of distributor everyone is running as well?
Old March 20th, 2015, 02:32 PM
ezzzzzzz
Mark Garrenton
I had one sitting in a 4.2 here at the house. It's tight but doable. That dizzy is going into the 4.0 I'm building for the 110. The GM module is dead reliable with no extra wires and available at every parts across the country as is the coil. Plus you get 40kv vs about 25k-30k with the stock coil. I think the clearance issue is with the earlier engines that had the water pump sitting higher up or a bolt on the intake manifold but it could still be worked with a bit of grinding.
Old March 20th, 2015, 03:34 PM
This is what I have on Trey's 4.2 in the 83 110. It has the Atlantic British module relocation setup and I have that bolted to the same plate the coil mounts to. This on a truck with a 4bbl edelbrock.
I drove it today to return a concrete mixer I had rented. That truck puts a smile on my face every time I drive it.
advice, distributor
WTT 1987 90 SW setup for ST setup javelinadave For Sale - Parts 0 July 19th, 2013 12:09 PM
FS: 3.9L Distributor & Coil/Ignition plate kiphartzell For Sale - Parts 6 April 30th, 2013 08:12 PM
Distributor OR Ignition Module? tdn Defender Technical Discussions 12 December 7th, 2010 12:52 PM
Aftermarket distributor options. draaronr Defender Technical Discussions 1 September 29th, 2004 07:30 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
