Advice for installing an adjustable panhard rod - Defender Source
Old September 28th, 2012, 09:01 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I will be replacing all of my steering linkage and my panhard rod soon. I will be replacing the stock rod with an adjustable one. Any helpful tips or advice to make this less painful? Should I do the linkage first or the panhard? Both of linkage bars are bent so I will need to replace them and then re align my wheels.
Thanks for any help you can offer, Jason
Old September 28th, 2012, 09:09 PM
From where? Will it have a Heim joint?
Old September 28th, 2012, 10:11 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
The panhard rod is not one of the fancy ones, just a little bigger than stock with the stock ends and Polybushes. I think I have all the necessary tools. I was just wondering if doing one first would make the other less of a pain. I will do the alignment myself, it is pretty screwed up, I tried adjusting it to make it a little better but the existing linkage is so old and tweaked that I was not able to even turn the rear bar.
advice
Adjustable Panhard Rod & top/bottom spring retainers Ray_G For Sale - Parts 1 June 17th, 2012 10:39 PM
Adjustable Panhard Rod Oliver Whiting The Vendors Loft 0 November 23rd, 2011 08:32 AM
RoverTym Adjustable Panhard Rod cbass For Sale - Parts 3 August 16th, 2005 12:41 AM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
» Defender Registry
90
clb1994
#401/500
ixselr8
Add your Defender
