Advance tdi timing... wow - Page 5 - Defender Source
Old April 30th, 2014, 04:51 PM
I wonder if somebody used thread lock when the put the nuts on. If so, can they be safely heated with a torch?
Old April 30th, 2014, 05:30 PM
Damage the heads? What are you using? A proper tool should never damage the heads. Use a 6 point socket.
Old April 30th, 2014, 06:46 PM
aosias's Avatar
aosias
Alexandra
1995 D90
That's what I am using and not one of the 3 will budge.
Old April 30th, 2014, 06:58 PM
I'm still confused. The heads should never get damaged. They are M6, I think, and would break with little force. If you had said "I snapped one", that would make more sense. Work them back and forth. Give them a little heat. Send a nasty email to whoever did the timing belt.
Old April 30th, 2014, 07:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Can't recall. Are they clockwise or counter clockwise?
Old April 30th, 2014, 07:45 PM
The video in post 73 appears to show standard threading so counter clockwise to loosen.
Old April 30th, 2014, 07:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
If that's the case I would just heat them gently with a torch and tap with a hammer onto the ratchet to shock them loose.
Old May 1st, 2014, 02:56 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Heat didn't help. One is rounded and can't get a socket to grip it. Other two aren't far off.
Old May 1st, 2014, 03:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Pictures please.
Old May 1st, 2014, 03:17 PM
aosias's Avatar
aosias
Alexandra
1995 D90
this truck hates me.
Name:	photo IP .JPG
Old May 1st, 2014, 03:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Looks like they've been abused and needs to be replaced. What are you using to turn them? Will a six point socket fit over them?
Old May 1st, 2014, 03:26 PM
aosias's Avatar
aosias
Alexandra
1995 D90
My 10 mm 6 point socket did this. They were fine until I started meddling.
And I still have to get the things out to set the timing, and replace them.
Old May 1st, 2014, 03:27 PM
The truck does not hate you. Whoever last touched those bolts should be flogged.
A quality 6 point on properly should hold those and not cause damage. You can also get the special ones to grip rounded heads.
If it were me, I would stop and order what is needed to do a timing belt including new bolts. Whoever was in there last can't be trusted and I would redo the work properly for piece of mind.
Old May 1st, 2014, 03:38 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I'm beginning to wonder if they are the wrong size bolts and that's why they are stuck and stripping.
Old May 1st, 2014, 03:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sounds like a little bit of self flogging might be in order. They may have been over tightened before. They shouldn't be that tight. There is a torque spec for all the bolts in the timing assembly. Make sure to find out what they are and get a torque wrench so you can tighten everything to the correct spec. The service manual is good and I also have a great Diff Lock article that I can send you that I found very helpful. Not sure how you managed to slip off with a socket. If they still will go on I would tap a hammer onto the socket handle (in the right direction!) to get them loose. Definitely get those replaced.
Originally Posted by aosias View Post
My 10 mm 6 point socket did this. They were fine until I started meddling. And I still have to get the things out to set the timing, and replace them.
Old May 1st, 2014, 04:03 PM
I've done those bolts on mine dozens of times and you only need to tighten them just a bit past hand tighten to hold your timing in place.
Mark Kellgren
KM4BOR
Old October 30th, 2014, 01:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Did they come out ?
- Charles Eames
Old October 30th, 2014, 04:28 PM
aosias's Avatar
aosias
Alexandra
1995 D90
No. I gave up. Now I just add a fuel additive every time I fill it and know that around a certain temp she's going to have some white smoke for a few minutes. Bolts are on the list to deal with at some point.
Old November 3rd, 2014, 09:06 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You need a bolt extractor, you can get one for cheap on eBay.
- Charles Eames
Old November 4th, 2014, 08:06 PM
Ruthiford
Jason
1986 D110
When the time comes, if you would like a hand, PM me... I'm in Golden. I would enjoy meeting another local Rover owner. Im also fair with a wrench....
tdi
200 tdi timing question snowkistdynasty Defender Technical Discussions 4 December 23rd, 2010 11:32 AM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
