Advance tdi timing... wow - Page 4 - Defender Source
Old April 10th, 2014, 06:36 PM
The drill bit will be fine. You can set the crank by sight by looking straight up through the flywheel drain.
Old April 10th, 2014, 06:40 PM
Shouldn't the drill bit be 9.5mm? (3/8")
Old April 10th, 2014, 06:43 PM
I use 9.5mm per M&D
Mark Kellgren
KM4BOR
Old April 10th, 2014, 07:03 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
correct - 9.5mm
Also can make a locating/locking tool from a wading plug
Old April 10th, 2014, 07:47 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Originally Posted by Mybluett View Post
correct - 9.5mm
Thanks. How do you make a locating/locking tool from a wading plug? And what is the diameter of a wading plug?
Old April 10th, 2014, 07:57 PM
you would need to drill a hole through the middle to stick a drill bit through it. I would "guess" about 1/8" would work.
you definitely want to get a proper one. There are spring loaded versions that lock into place on TDC while you are turning it from the front.
you can buy just the locking pin and timing pin on ebay.uk or difflock
Mark Kellgren
KM4BOR
Old April 29th, 2014, 02:18 PM
aosias's Avatar
aosias
Alexandra
1995 D90
So- I ordered the flywheel locking pin and am now set to do the timing. I can't for the life of me get the flywheel to turn more then a quarter turn either direction.
I think that I am 180 degrees off since I am close on the injection pump but not on TDC.
Is it really just a crescent wrench to the bolt on the flywheel pulley and brute strength? Does it matter which way I turn it?
Old April 29th, 2014, 02:32 PM
You should always turn an engine in the forward direction. They are never intended to be spun backwards. It should turn relatively easily. You are in neutral.......right?
If the engine has been running, you are not 180 degrees out.
Old April 29th, 2014, 03:14 PM
aosias's Avatar
aosias
Alexandra
1995 D90
So, apparently I missed the neutral step. Makes it a lot easier.
Now on to my next idiot question. This hole in the photo is where I put the the flywheel locking pin correct? It doesn't seem like there is anything going on there when I turn the pulley. I've gone around twice and I can't get the locking pin to engage to tell my I am TDC and I can't see anything in the hole.
Photo is from the ground looking up.
Old April 29th, 2014, 03:16 PM
No. That is the timing cover drain. You want the clutch housing at the other end of the engine.
Old April 29th, 2014, 03:29 PM
Just FYI, you don't really absolutely have to have the flywheel locking pin. You simply need the flywheel timing slot to be lined up on the hole with the piston at TDC. Once you have that, DONT TURN THE CRANKSHAFT.
Also, be sure that the timing marks on the timing cover and pulleys all line up and that the piston is at TDC on the compression stroke before you go taking the belt off. (Remember the crank spins twice for each full four stroke sequence.) You should be able to get the pin in thru the pump pulley hole. Lock the injection pump using the locking bolt on the side of the pump. Only when these conditions are met do you take the belt loose. That way there is no possibility that you'll get it out of whack on reassembly.
Be sure to replace the spacer wedge thing on the injection pump lock bolt so that you don't damage anything.
Old April 29th, 2014, 04:08 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Do your self a favour, and watch this video
should help understand whats behind that cover
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 29th, 2014, 04:10 PM
I think he is simply checking the timing....not doing a belt. And looks like a 300TDI.
Old April 29th, 2014, 04:12 PM
roverman2010
1985 LR 90 200Tdi
might help understand which end of the engine he is working
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 29th, 2014, 07:50 PM
aosias's Avatar
aosias
Alexandra
1995 D90
It's she not he.
Thanks for the video, I need an education in diesels in general.
Thankfully I'm just doing checking the timing to see of that takes care of some white smoke I have and not trying to change the timing belt.
Old April 29th, 2014, 08:11 PM
roverman2010
1985 LR 90 200Tdi
My bad, she
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 30th, 2014, 01:20 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Got it TDC at the flywheel.
Now, I can't get the 3 bolts on the IP to slacken so I can adjust it. Am I missing a step here that would make this easier?
I have the inspection plate/AC pulley off. The 3/8" drill bit won't fit all the way in- maybe an inch. From what I've read that means my timing is off and I need to slacken the 3 bolts and then turn the larger bolt clockwise until the drill bit goes in easily.
Old April 30th, 2014, 02:15 PM
What do you mean they won't slacken? They are little bolts. Anywho, one lose, the pump will force the shaft to the limit of the slots. Use a wrench on the center nut to rotate within the limit of the slots to get the timing pin in place.
Old April 30th, 2014, 04:23 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Correct. I can't get them to turn without doing damage to the heads. What happens if they don't come out and get mangled in the process of trying to get them out?
tdi
200 tdi timing question snowkistdynasty Defender Technical Discussions 4 December 23rd, 2010 11:32 AM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
