Advance tdi timing... wow - Page 3 - Defender Source
Old December 9th, 2012, 08:34 PM
Originally Posted by Manimal View Post
You mentioned a plunger lift of 1.6MM but nothing about where or how to adjust it. How is that done?.
I'm too lazy to look for you, but I'm sure it is up in this thread. You use an adapter with a dial indicator on the end of the pump to measure plunger lift. It is more accurate that the pin method.
Old December 9th, 2012, 10:46 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I've combed the thread. It has been mentioned but no description on how it's done. So the dial with adapter goes into the same hole as timing pin?
Old December 9th, 2012, 11:08 PM
No. It goes into the pump itself from the other end. Google Bosch VE timing and read up on it.
Old December 30th, 2012, 10:25 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I finally got to making another round of adjustments and I think I found the sweet spot. I still have black smoke puff at start up and had some blue smoke when cold but it went away after the test drive. It seems more snappy now and no noticeable excessive knocking whether at idle or while driving.
It appears a very small advancement did the trick for me. I reset the timing again and used the timing pin which is 9.39MM. I replaced it with a 9.15MM drill bit so only a very minute (if at all) advancement.
Old March 2nd, 2013, 02:38 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
OK gents, I decided to try this out since my motor seems to be running OK for the moment.
I have the normal timing pin in, loosen the three bolts, and put in the smaller drill bit. However when I go to turn the pump nut it really won't move. The three bolts are loose enough that I can twist them with my fingers, so I don't think that's it. I can't turn it enough to even make the bit snug.
How easy was it for you guys to turn the nut? I don't want to get a breaker bar on there and heave over and then snap something.
Old March 2nd, 2013, 09:46 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You won't snap anything with the breaker bar. You need a breaker bar to get enough force just be gentle with it and increase force gradually. You're not just turning the nut, the whole pump pulley will rotate along with the nut. Push with breaker bar counter clockwise until it touches the smaller drill bit. Hold it in place as you tighten the tree bolts. Mine took several (small) adjustments to get it just right.
Old March 2nd, 2013, 11:33 PM
navydevildoc
Neill Thornton
Carl.... Counter-Clockwise? I have been trying to move it clockwise. I think I am actually up against the end of the adjuster window of the bolts on the pulley.
Old March 3rd, 2013, 12:00 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sorry. Clockwise.
Old March 3rd, 2013, 01:14 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You shouldn't be. What if you reset it and start over? There should be a way to reset/re-align the adjustment window. See my previous posts.
Old March 3rd, 2013, 10:07 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Question for Steve... White smoke?
Steve:
Do you know if your fuel had been turned up from factory settings to start with?
We had a 300TDI 110 in the shop last summer that the owner changed the timing belt on and at the same time turned his fuel up. He had the white smoke issue. It was a Disco engine with that extra linkage on the side of the pump. There was a steady fuel leak behind this linkage.
After addressing the leak with new O-rings and having the leak stop and start again, we ended up swapping out the pump. Afterwards, the white smoke was gone. I suspected all along the timing was retarded, but the owner was in a hurry to get back on the road. We did not "adjust" the timing, bit noticed that the replacement pump was not full of fuel so it didn't have that tendency to resist and snap like one full of fuel. So it made setting the pump according to the timing pins easier. Do you think getting all the fuel out of the IP would effect your timing process? make it easier?
RDavisinVA
Old June 21st, 2013, 01:26 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Hi Rob,
Apologies for the months long delay... just saw this while re reading threads.
I have messed with my fueling previously but I have tried to turning it back down with no change in smoke... I'll try again though.
I'm not quite sure what your getting at with the IP full of fuel.... but I'm interested because my smoke is back.
I'm going to start another thread to hopefully sort this out.
Old September 9th, 2013, 10:43 AM
For those attempting to use the timing dial gauge (which I am) on the 2.8 TGV IP, per M&D, here is the plunger spec:
"The correct target lift on the 2.8 motor is 1.44mm.
other than the different setting, the procedure is the same as on 300Tdi."
Mark Kellgren
KM4BOR
Old September 9th, 2013, 12:57 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Good to know. Did they say this will make a significant increase in power?
Now add an intercooler upgrade and you are all set
If anyone is in the market for an intercooler upgrade, please shoot me a pm. I have an order coming in
Legend in My Own Mind.
Old September 9th, 2013, 01:00 PM
That's the spec for the engine, just like the 1.54mm for the 300 TDI. They also said the timing pin in 9.5mm, just like the 300 TDI. they actually just use a 9.5 drill bit in their shop.
If I didn't mention it elsewhere, the flywheel locking pin hole is threaded differently from the 300 TDI. I'll post the thread size here this week. I had to remove the flywheel access bolt, get another bolt, drill a hole through it, and use that with a drill bit to actually lock the flywheel on mine. Not sure why International didn't just go with the 300 TDI bellhousing style locking pin and location. It's so much more convenient.
Mark Kellgren
KM4BOR
Old April 10th, 2014, 01:48 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I am going to try and adjust my timing. I have white smoke when idling with a cold engine and on downhills.
Question- I have AC and there is a pulley over the inspection plate. Do I need to remove this plate/pulley to get to the 3 bolts or did this replace that and I need to put a 9 mm bit in the square hole, loosen the bolts, adjust timing and then tighten the 3 bolts?
Old April 10th, 2014, 02:40 PM
yes. step 1 is to remove that pulley. you need to anyway, because your crank turns twice for every one turn of the IP. so after you pull off that AC 0pulley, get an adjustable wrench out, grab your dognut and turn til the flywheel is lined up on TDC. you would expect to see the ip pulley timing hole on top. if it's on the bottom, then go around again til it's on top. of course, you 300tdi guys have a more convenient flywheel lock hole on the bottom than us 2.8 guys.
once crank and IP are on TDC, that when you loosent the 3 bolts and check with your timing pin, and adjust as necessary. NEVER go counterclockwise on the IP hub nut to adjust the pin and timing. rarely will you ever need to. If that IP nut ever came loose, you'll have to pull the IP and take it to a Bosch shop to have the hub realigned.
almost always, the IP will be retarded when it's out of time, which means you have to turn the IP nut slightly clockwise to get the pin in. no risk of loosening the nut in that direction.
------ Follow up post added April 10th, 2014 02:40 PM ------
ac pulley bolts are 13mm, and the IP pulley nuts are 10mm.
Mark Kellgren
KM4BOR
Old April 10th, 2014, 03:59 PM
aosias's Avatar
aosias
Alexandra
1995 D90
where is the dognut? Do I need to worry about cranking on that- like will it start the motor with my hands in there?
Also- I see the arrow for TDC, but I can't seem to see the notch in the pulley to line it up. The YouTube video I was consulting doesn't make it very clear either.
Old April 10th, 2014, 04:22 PM
the "dognut" is the nut on the crankshaft. you aren't going to break that loose on your own. no chance the engine will start with the fuel stop solenoid off. When I am lining up TDC, I just use an open ended monkey wrench on the dog nut and turn it clockwise. I put yellow painted marks on the harmonic balancer so I can visually see when I'm TDC, to make it easier to lock the flywheel.
you need to have a flywheel locking tool, that inserts in the bottom of the flywheel housing. I assume you have that? Tools required are the timing pin and the flywheel locking tool.
------ Follow up post added April 10th, 2014 04:24 PM ------
the only reason to use the mark on the harmonic balancer is to make it easy to get the flywheel locked in TDC. if you can't see the mark on the balancer, then you'll have to look in the hole for the flywheel locking tool and look for the notch, and you can't look in the hole and turn the dognut yourself.
Mark Kellgren
KM4BOR
Old April 10th, 2014, 06:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Sadly I am not prepared. I do not have a flywheel locking pin or timing pin. Was planning on a 9 mm drill bit. Ideas on where to source these tools locally or a cross reference to something in the US?
Old April 10th, 2014, 06:32 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Check rovahfarm.
tdi
200 tdi timing question snowkistdynasty Defender Technical Discussions 4 December 23rd, 2010 11:32 AM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
