Adjusting wheel stops on orgin equip - Defender Source
Old December 3rd, 2007, 02:05 AM
Happyxhour
Robert
94/Defender
Hey guys had a quick qustion on adjusting tire stops on orignal equip. I was running BFG 265 75R16 MT on my D90 and had the guys at Big yO Tires swapped out to 265 75 R16 AT for some tires I picked up with less than 2G miles. I know not pushing the envelope here but for some reason I am getting rubbing on the new set of tires after full cranking.
I havent been able to see actually where they are rubbing (control arms etc) at full articulation yet but was just wondering if swapping stock size to stock size would the steering stops need to be adjusted at all?
Thanks for info...
Old December 3rd, 2007, 09:43 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Doesn't seem like they would unless the lugs stick out further on the all terrain than the muds. If you need to adjust the bump stop, that is really easy and takes about 5 minutes.
Old December 3rd, 2007, 10:45 PM
Happyxhour
Robert
94/Defender
Thanks Paul...searched previous thread on adjusting them. Thanks!
wheel
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
» Defender Registry
D-Storm
LI90
Bernie
SGandMT
Add your Defender
